7afe with 4agze tranny
06-19-2008, 07:25 PM
Im building a 7agze with a 4agze tranny (FWD).
Now ive already gor the tranny and it bolts on nicely. Now the challange here is to get the flywheel/clutch combo correctly. I was first thinking of a custom flywheel, but thats just to expensive for now. Got an offer from fidanza for a custom flywheel at $1500. The other option would be to get a 7afe clutch that fits the 4agze spline. Now ive been talking to both fidanza and spec clutches about this and both offered me a clutch solutoioon. Fidanza is cheaper, but wont provide the correct bearings and pilot tool, while spec will provide the correct bearing etc. Now the question, fidanza or spec? I havent got any experience with their clutches so hopefully you guys can enlighten me |
06-21-2008, 08:06 PM
Did you know Toda make the flywheel for 7AFE Flywheel? The part # for Toda is 22100-7AF-000. Basically, The 7AFE Flywheel is 212mm just like 4AGE but only have 6 bolt to bolt on to the crankshaft.
Maxwell Arancon Vice President PASS RACING INC 148 S.8th Ave, Unit-F City of Industry, USA [email protected] http://www.passracing.com
06-21-2008, 09:33 PM
thanx for the info Max, ill take a look at it.
Im also checking the 225mm flywheel from a 3TC. I measured the 4agze flywheel I have here and its ~230mm, so if im correct I have a late E58. Toyota didnt put identifycations on the tranny |
06-23-2008, 07:53 AM
All GZE trans is E serious that is the same of the SW20 Turbo. Did you know The LSD of AW11 GZE and SW20 Tubro are the same part #? Hope will give you some idea.
06-28-2008, 11:17 PM
Sounds like an appropriate combination man1 Good work.
| tranny fluid | drift | 10 | 16,207 |
04-21-2012 06:10 AM Last Post: assassin10000 |
| Sr86 engine/tranny mounts | szmk89 | 1 | 4,562 |
10-31-2010 06:38 PM Last Post: szmk89 |
| 7AFE + 4AGE head + turbo ...Anyone ? | Uzelac | 13 | 37,990 |
09-02-2010 08:23 AM Last Post: Sambo |
| TRANNY | ae86xye | 3 | 5,530 |
09-22-2008 04:19 AM Last Post: F0Bman |
| Which engine/tranny mounts??? | Aram | 7 | 9,066 |
08-12-2008 06:03 AM Last Post: F0Bman |
