4x100 conversion
12-05-2012, 11:05 AM
4x100 conversion
did some one ever tryed this?
the front is easy, grp4 can fab the hubs in 4x100 but the rear i dont know, there is no room to redrill the hubs. can you take those apart anyway? |
12-05-2012, 02:55 PM
4x100 conversion
Weir Performance offers halfshafts for Hachis. I´m sure they´re able to make some in 4x100.
AE86 Full Hybrid - Burns rubber and gasoline |
12-05-2012, 05:05 PM
4x100 conversion
yeah i know but i try to avoid them because they take for ever
thx for the input anyway |
12-05-2012, 10:10 PM
4x100 conversion
If you don´t want to spend the money on new hubs and get new shaft made up for 1000000€ just get them redrilled, any decent machine shop can do it.
I´ve seen the front changed to 4x108 (Ford), no dramas. There is loads of room on the rear, you´re going smaller it so even better. jsut remeber that the disks need redrilling as well on the rear. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
12-05-2012, 10:28 PM
4x100 conversion
i don't mind spending some money
redrilling is the last option, not a big fan of it |
12-06-2012, 12:28 AM
4x100 conversion
'87 levin coupé |
12-06-2012, 12:46 AM
4x100 conversion
Eifelaner Wrote:i don't mind spending some money There is nothing wrong with redrilling! So you answered your question yourself... New alloy hubs with the right studpattern and custom shafts from Weir. I just bought a 4,7 CWP from Weir and it took 2,5 weeks from payment to arival it, not to bad considering its from the states, goes through the customes etc... What wheels are you going for? They must be epic if you thinking about going through all this! 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
12-06-2012, 08:49 AM
4x100 conversion
I run 4x100 bolt on conversion spacers because my 2nd car is a miata quite happy with it
got custom ones not more expensive than standard ones http://spurverbreiterung.de/index.php?la...aed1e2e385 http://nuudelbahn.wordpress.com/ http://www.superlapbattle.lu https://www.facebook.com/SLBRaceleague |
12-06-2012, 09:31 AM
4x100 conversion
Eifelaner, try and find Spence from Dwarfcarproducts on the dwarfcar forums. He used to have a website online with dwarfcar rear axles. Very nice conversion to fully floating at approximately the same price as the weir stuff.
The fully floating conversion strengthens the axle by feeding most of the tire forces into the axle casing. It also allows you to change rear camber and toe by simply adding shims under the rear hubs. They are custom built, so it would be easy to change the pcd on the hubs. A wheel to steer the front of the car A pedal to steer the rear |
12-06-2012, 11:14 AM
4x100 conversion
Why would someone would want to do that if I may ask?
| 20v Blacktop conversion.... | Mylesmck | 0 | 2,121 |
04-29-2024 05:48 PM Last Post: Mylesmck |
| Kouki to Zenki Levin grill conversion? | Mylesmck | 6 | 6,770 |
02-08-2024 10:30 AM Last Post: r.ave |
| AFM to Map Conversion | ps13michi | 3 | 6,703 |
| Sub panel and rotary-button replacement for Levin -> Trueno conversion | gh0st | 9 | 11,554 |
11-05-2021 08:17 PM Last Post: gh0st |
| AE86 single wiper conversion | kazi | 6 | 13,685 |
08-26-2017 08:47 PM Last Post: kazi |
