4agze piston in 4age motor
10-10-2008, 09:47 AM
Ken i puth the 4agze piston in one 4age motor?(to make ihttp://cgi.ebay.com/ebaymotors/4AGZE-Pistons-Low-Compression-L-K-No-Resrv-4AGE-BOOST_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1229Q7c39Q3a1Q7c66Q3a2Q7c65Q3a12Q7c240Q3a1318QQ_trksidZp3286Q2ec0Q2em14QQhashZitem140273954673QQitemZ140273954673t turbo)
10-10-2008, 09:48 AM
http://cgi.ebay.com/ebaymotors/4AGZE-Pis...0273954673
10-10-2008, 02:40 PM
only if you have the correct crank and connecting rods. (pistons of the 4agze are 20mm pin and the standard 3 ribbed bluetop has 18mm pin.
10-10-2008, 04:37 PM
Moved to technical. This is hardly a project. Wink
[Image: AEU86 AE86 - 4agze piston in 4age motor]
10-14-2008, 05:47 AM
Can be done with no troubles. AS long as you have the 20mm rods. If not then you might need a bushing pressed in.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
  Piston ID kazi 5 7,518 08-11-2019 03:34 PM
Last Post: totta Crolla
  86mm piston wizards... fantapants 6 8,127 05-30-2017 02:36 PM
Last Post: jdm86gtz
  Piston Identification Alex170984 3 6,958 05-17-2016 12:47 PM
Last Post: Alex170984
  Piston availability totta Crolla 3 6,893 09-03-2015 09:32 PM
  which piston is this? ditn 10 15,119 07-04-2014 03:18 PM
