4agze ae86 wiring.
11-05-2012, 07:58 PM
4agze ae86 wiring.
Hi guys, I've fitted a GZE into my ae86. And I'm stuck with wiring. Mainly because, my GZE wiring has its own starter/ alternator loom in with the engine loom, and the ae86 starter/alternator looms are on the car.
I'm going to use the one already on the car, and cut mine out , but I need to connect this inside the car for it to work. The colours I have to connect are these, AE86 14 pin connector.../....GZE ECU connector Batt live, red,white trace ...../.... Red,white trace Ign live, black,red trace..../.... Black/red trace Fuel pump trigger, green,red trace..../.... Green,red trace Speed signal, blue,white trace..../.... Purple,white In my GZE loom I have a thick black for a starter signal, but where do I connect this to? Basically I need the wire colours to get this cranking.. Not just the ones to run the ECU. I don't know what this pale yellow connector does in my ae86 , on the left of the picture. ![]() Cheers |
11-05-2012, 08:44 PM
| 4agze ae86 wiring. | |||
11-05-2012, 09:26 PM
4agze ae86 wiring.
It doesn't mention the starter wires... But I'll connect those up and see how I get on.. Cheers
11-05-2012, 09:59 PM
4agze ae86 wiring.
I did look that long time ago and i think there show all you need to make wiring harness
| Tail light wiring... | Mylesmck | 4 | 3,784 |
02-02-2024 12:36 PM Last Post: Mylesmck |
| Lambda sensor wiring | sam3007 | 10 | 9,449 |
| 4A-GE wiring engine to chassis connectors | Lykowsky | 4 | 10,334 |
06-20-2019 11:38 AM Last Post: Lykowsky |
| Some wiring help needed | DJexor | 5 | 8,456 |
| AE86 Headlight + wiper wiring (levin) | bozu | 11 | 22,630 |
09-19-2017 02:06 PM Last Post: banpei |
![AEU86 AE86 - 4agze ae86 wiring. [Image: AEU86 AE86 - 4agze ae86 wiring.]](http://i255.photobucket.com/albums/hh132/jono395/image.jpg)
