4age stock bigport on turbo
01-16-2014, 01:14 PM
Hi there, I have a almost stock 4age bigport bluetop with AFM originaly bought in Switzeland but with no cat. Engine is stock but 4-2-1 exhaust manifold and under axle silincer system. It has egr removed and HKS fcon + HKS gcc controller piggyback ecu.
THis ecu is mainly fot turbo and SC aplications from I know. I would like to know how much turbo press is safe and reliable to run with an engine on this spec and on OE gearbox and axle. Would be a better option a SC route? I have a brand new IHI turbo sitting arround and I guess it would be cheaper for me the turbo way. I dont expect a huge amount of power, just a little more torque and few bhp to have more fun on track. I run 185 on the rear. Thanks in advance, Cheers |
01-16-2014, 01:30 PM
The hks supercharger kit for 4age ran something of 6/8 psi i believe on a stock 4age but its hard to find info on it.
if you can read japanese here is the brochure ![]() ![]() You could also swap in pistons from a 4agze or to source,excellent beginning for turbo or supercharger route ![]() |
01-16-2014, 02:18 PM
Thanks for the info mate, unfortunatly i cant read japanesse. I was planning on a add-on items without change internals. Maybe on the future i will rebouild the complete engine.
Cheers |
01-16-2014, 02:31 PM
np
![]() I actually have the same idea of higher compression with low boost. The hks kit would be perfect for you but they are so rare. 6-8 psi is a safe number then i think,im trying to find the exact number the supercharger kit ran but its hard if you cant read japanese. |
01-16-2014, 05:08 PM
Sure it is hard!
I was planning on a eaton m45 from a mini or a mercedes with the mini mechanical bypass valve, but this SC is allways a bit more expensive than i want to invest and I cant find one on my local scrapy (they only sell complete engine) So due to I have a new turbo behind the bed i was thinking on this route. Cheers |
01-16-2014, 06:57 PM
yeah tbh i wouldnt go the m45 route,will be buckets of money.
If you are a supercharger fan like me id suggest finding a 4agze and going from there,but it still wont be cheap. if you manage things with that ecu the cheapest will be a small turbo with low boost i think on youre current setup |
01-16-2014, 10:52 PM
Thanks mate, cheers
01-17-2014, 12:41 AM
i have an ae86 4ac. i bought a brand new 4age blue top big port engine and installed turbo.stock engine stock internal. now its going @1 bar with garret 28-71
i have a microsquirt standalone ecu. 550 cc rc injectors. intercooler etc. here are videos 0-400 meter 14.8 with an open diff http://www.youtube.com/watch?v=d3fdr2wrc5Y and accelaration http://www.youtube.com/watch?v=Ml0bIG5m-6E ![]() ![]() |
01-17-2014, 01:02 PM
![]() ![]() Man thats what im talking about. Are you using stock gearbox and rear axle? Cheers |
Digital speedometer on stock dashboard | FanIsHere | 0 | 1,857 |
82mm Stock compression Pistons | apardal | 4 | 3,399 |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 14,698 |
Most stock-resembling exhaust for the AE86? | DaLanZhu | 4 | 6,190 |
Early tvis red top from e9 gti small or bigport? | Ryo | 3 | 8,104 |
