4age idle/fuel problem
06-22-2011, 05:26 PM
I have a problem with 4age not running properly. It starts fine, but runs only for a few seconds while 5th injector (cold start) delivers fuel. Fuel pump is good, injectors also fine.
Maybe pressure problem in fuel rail? ECU problem? Here is the clip http://soundcloud.com/order66-1/4age-start Anyone have any ideas? |
06-22-2011, 07:26 PM
What fuel pump are you using?
What is the fuel preassure? Measure it! Drifting - best fun you can have in your car with your pants on! |
06-22-2011, 09:15 PM
Has this happened after work has been done on the fuel system ?
06-23-2011, 08:20 AM
Do you hear the injector ticking after the cold start injector stops? Even without fuel you can hear em clicking away. Maybe put a screwdriver on top to help you feel them.
I'm guessing an injector ground is loose somewhere. A wheel to steer the front of the car A pedal to steer the rear |
06-23-2011, 07:35 PM
ZaX Wrote:What fuel pump are you using? OEM, got it from you 2 years ago. Tested on celica 1.6 that was in the garage. We will measure it as soon as manometer arrives, after the weekend I believe. totta Crolla Wrote:Has this happened after work has been done on the fuel system ? Don't know, car has been sitting for years, than I got it 3 years ago and started restauration. This was probably the original problem why the car hasn't been run for years. I'll take a closer look at injectors tommorow. |
06-23-2011, 09:07 PM
Check your EFI main relay nr 2. Injectors should always have 12v coming from this relay with the ignition on, the ECU switches them to ground. The start injector is controlled by a time switch, so has nothing to do with the ECU at all.
Just check your injectors for 12v, if you cant find it, either the relay is dead, or it's a fuse (wiring is always the last suspect). FABRICA MI DIEM, PVNC! |
06-24-2011, 09:07 PM
It was problem in fuel rail full of rust peieces from old fuel tank. Injectors and rail cleaned and engine works almost like charm :mrgreen:
The cooling radiator is next, then spark plugs and probably leads, and them we shall see if any new problems will arise. Thank you all for help |
| Blacktop 20V high idle | Bravothreezero | 3 | 732 |
08-28-2026 01:11 PM Last Post: jdm86gtz |
| No idle below 2000 rpm rich running | Steller Engineering | 3 | 4,175 |
| Engine starts/revs but no idle | GenkiMotors | 17 | 14,757 |
| Fuel Natural 95 E10 for 4age insted of E5 | Ryo | 11 | 15,570 |
09-29-2021 12:56 AM Last Post: Ryo |
| exhaust odor/idle MOT issue | Ryo | 7 | 11,318 |
