4age 16v head on 20v Bt block running on MegaSquirt
03-29-2007, 08:46 AM
I guys my questions are about my particular setup a 16v red-top head on a black-top block running with MegaSquirt 1 PCBVer2.2. I will also use stock blue-top wiring harness and stock igniter from 4age 16v working with stock dizzy+MSD blaster2.
Okay to begin the setup will run ITB's from the Black-top throught an adapter plate to fit 16v head. My first questions is about sensors I will need to use to run the MegaSquirt. I just want to know if someone have already try the setup and where you have put AIT sensor on open ITB? I have see setup running MS with AIT sensor in intake manifold but I cant figure it out with open ITB's without Int manifold. Also what I need to get the Fast Idle work? On the 4age 16v I think its a mecanical unit in the throttle body working the Fast Idle with coolant temperature but I dont really know what to do with open ITB's. Do you know if the Fast Idle with open ITB on 16v head run with a sensor or with a mecanical unit? Or if idle is only provide by ajusting throttle plates. My last question is about knock sensor...I have found a unit to plug in MegaSquirt which allow you to run a knock sensor with MS. Do you know if modifications can be done to the 16v head to run a knock sensor. I will take the knock sensor from the Ae111 head, re-wire it and run it with MS.(Not necessary but can be usefull!) Also if someone have advises about sensors, open ITB on 16v head, and MegaSquirt wiring dont hesitate. Thanks Hugo |
20v BT Head | filh | 4 | 782 |
03-11-2025 09:51 PM Last Post: oldeskewltoy |
4AGE cylinder head plug removal | Ivan141 | 5 | 2,627 |
No idle below 2000 rpm rich running | Steller Engineering | 3 | 1,889 |
Running issues | sam3007 | 6 | 3,373 |
Question about 4AG 20v Engine Block | CHACAMAN | 1 | 1,987 |
