4ac gearbox on 4age
05-23-2016, 11:01 PM
4ac gearbox on 4age
Can i use a 4ac gearbox on my 4age engine ?
Is there any difference with the T50 tranny ?
What about ratios ?
Sent from my SM-G900F using Tapatalk
05-24-2016, 12:34 PM
4ac gearbox on 4age
All T-50 gearboxes have the same internal ratios.
The bellhousing can be swaped, the only potential problem is the output shaft spline count. Early T-50s had 20 and later models had 22 count. You can still get different speedo drive gears from the dealer to match your rearend ratio. Dave W
05-24-2016, 10:16 PM
4ac gearbox on 4age
Digging from my memory I believe the 4AC was mated with a different bellhousing. The clutch slave cylinder is on the other side which is kind of in the way of the 4AGE exhaust manifold. Also the starter motor is on the other side, so the easiest is to swap either the bellhousing or find a 4AGE T50.
[Image: AEU86 AE86 - 4ac gearbox on 4age]
  ford type 9 gearbox with 4age engine filh 29 61,534 01-11-2015 01:02 PM
Last Post: filh
  4ac crank on 4age! Ghetto 7 13,120 12-05-2014 10:42 PM
Last Post: Uzelac
  Need help asap with 4ac to 4age!!!!!!! JDMjonSR5 6 15,635 05-14-2013 12:12 PM
Last Post: JDMjonSR5
  AE86: 4AC to 4AG (16v) Wiring Diagrams? yellowsnow4free 6 17,601 09-12-2012 01:52 AM
Last Post: yellowsnow4free
  Need help (4ac engine tuning) fullybuiltmiata 3 8,429 08-20-2012 09:25 PM
