4a-ge Oil Pressure Sensor Gauge, i need info
10-25-2011, 03:37 PM
It doesn't work because it's disconnected, nothing more
With the time the connector loose grip and it disconnect itself with the vibration. If your fingers are small maybe you can reconnect it without unbolting the power steering pump. |
| Messages In This Thread |
4a-ge Oil Pressure Sensor Gauge, i need info - Mattolo - 10-24-2011, 12:51 PM
Re: 4a-ge Oil Pressure Sensor Gauge, i need info - Project D - 10-24-2011, 06:05 PM
Re: 4a-ge Oil Pressure Sensor Gauge, i need info - Mattolo - 10-24-2011, 06:30 PM
Re: 4a-ge Oil Pressure Sensor Gauge, i need info - Project D - 10-24-2011, 09:59 PM
[] - Project D - 10-25-2011 03:37 PM
| map sensor cheating? | fdsjakl890 | 8 | 4,037 |
08-26-2025 01:12 PM Last Post: Ivan141 |
| EUDM gauge cluster | banpei | 22 | 14,031 |
| Lambda sensor wiring | sam3007 | 10 | 9,447 |
| Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 26,595 |
| Water Temperature Instrument not moving - Sender Gauge | Hama86 | 8 | 11,675 |
