4a-ge Oil Pressure Sensor Gauge, i need info
10-25-2011, 09:28 PM
Its in the middle of that doorbell like thing. You just slide the connector over it. This wire commonly lets loose, you might want to tighten the connector with a screwdriver or something like that before refitting the wire.
10-26-2011, 10:50 AM
Ivan141 Wrote:Its in the middle of that doorbell like thing. You just slide the connector over it. This wire commonly lets loose, you might want to tighten the connector with a screwdriver or something like that before refitting the wire.The connector itself slide in one side, right? OK, now I understand, I thought that was a connector to plug in the cable ![]() thanks guys! |
map sensor cheating? | fdsjakl890 | 8 | 819 |
08-26-2025 01:12 PM Last Post: Ivan141 |
EUDM gauge cluster | banpei | 22 | 8,005 |
Lambda sensor wiring | sam3007 | 10 | 6,378 |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 23,339 |
Water Temperature Instrument not moving - Sender Gauge | Hama86 | 8 | 9,280 |
