4AGE camshafts (again)
12-11-2012, 03:08 PM
It was using a fair bit of oil before I took it off the road.
There is also evidence of oil around the intake manifold ports when I took that off last week. |
12-11-2012, 04:12 PM
"I was going to get a hold of some Supertech valve guides instead of crappy ones you get pattern part gasket sets."
I guess you mean valve stem oil seals Alex ? If so then I would use genuine Toyota ones. An analogue brain in a digital World |
12-11-2012, 04:14 PM
If you did mean valve seals I think I still have a set or even too genuine Toyota ones lying around.
AE86 ex-daily |
12-11-2012, 08:52 PM
Sorry I did mean the oil seals.
12-11-2012, 09:55 PM
When it comes to the HG, even though i'm going to get it bored to 81.5mm can I still get away with a 81mm bore gasket?
Cheers |
01-03-2013, 09:17 PM
I've got some photos of my bearings if anyone is interested...
One of the main ends is a bit half and half, but i'll measure the crank journal to check its in tolerance before I do anything. Hope people like my uncomplicated numbering system lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
03-19-2013, 02:41 PM
Just a little update...
I have finally measured my deck to piston shoulder height and it is around 0.2 to 0.17mm. The block deck is in good condition so will not be decking it. I will be using a 0.0036" Cometic Metal Head Gasket All that's needed now is to disassemble the head, take the block apart again and take it to a machinists. I'll then try and afford the camshafts ![]() |
Need help again. | panda_tureno86 | 3 | 4,651 |
03-04-2012 06:17 PM Last Post: panda_tureno86 |
Again: LSD oil | Dino86 | 11 | 14,486 |
09-20-2010 08:09 AM Last Post: Project D |
What camshafts would be nice? | PatrickAE86 | 44 | 46,391 |
08-25-2010 01:06 PM Last Post: Uzelac |
Gear Box option - again? | KD2229 | 11 | 17,019 |
11-27-2009 03:10 AM Last Post: KD2229 |
engine problem again overheating this time !!!! | filh | 11 | 12,586 |
06-08-2009 08:40 PM Last Post: Gnugfur |
