4AGE 20V clutch problem.
07-06-2008, 10:21 PM
I have just fitted a 20v silvertop, I seem to have a problem with a harshness coming through the clutch, I just fitted a new clutch kit. Does anyone have a manual/guide/picture for fitting this.
Cheers
Ivan
1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1
07-06-2008, 11:04 PM
Other than having to fit a pilot bearing (since the FWD gearbox didnt require one), this is exactly the same as fitting a clutch to a 16V
07-06-2008, 11:24 PM
Do you have any pictures of the pilot bearing or manuals guides etc. I not really that familiar with the clutch setup.
Ivan
07-06-2008, 11:30 PM
Take a look through the online manual mate http://files.aeu86.org/manuals/AE86Manual.pdf Thumbs up! I'll see if I can track down the part number for you, it should be amongst the forums somewhere.
EDIT: Found - pilot bearing 90363-12003
07-07-2008, 04:31 PM
Cheers for the info, I was told the part no on the bearing is 6001, is this correct and could be got from a bearing supllier.
Cheers
Ivan
07-07-2008, 11:38 PM
I quoted the above number personally, but that figure may work aswell for all I know.
07-11-2008, 09:40 AM
Look here....
http://www.aeu86.org/viewtopic/wanted-in...ot+bearing
6001-2RS available cheap from any industrial bearing shop Smile
Cheers... jondee86
07-13-2008, 10:51 PM
Hmmm. Seems as if you might need to lube up the connections, with lithium grease.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
07-13-2008, 11:54 PM
I took the engine out again, and fitted the crank pilot bearing, but I'm still having problems with the clutch. The clutch has been bled and has normal biting point etc. But if you put the car in gear, kepp the cluch into the floor, then rev the engine to 4-5K the car moves back as if the clutch is engaging. Any Ideas? I'm going to pull it out a agian and maybe fit the old clutch.
Cheers
Ivan
  20v exedy clutch XandyX 3 7,454 10-16-2018 02:40 PM
Last Post: pack
  Machining Pistons to run 20v head... And FCR's on a 20v? PazzaAE86 2 6,818 09-15-2013 01:08 AM
Last Post: jondee86
  Clutch pedal problem andee17 3 6,377 07-25-2013 11:57 AM
Last Post: jondee86
  20v coolant problem Bravothreezero 8 12,765 07-15-2013 03:25 PM
Last Post: Bravothreezero
  Clutch problem Rascal21 4 7,357 05-31-2013 06:00 PM
Last Post: Alex170984
