4AGE 20V BT timing belt and tensioner
03-09-2012, 12:04 AM
I'm thinking about using the 16V timing belt tensioner on my 20V Blacktop.
I realized that the belt itself is different for the Blacktop, so I will have to use the original one. Is it possible to use the 16V tensioner, while still using the 20V BT oil pump? I don't have the engine with me at the moment so I can't really check it out. Thanks
86'LEVIN Track Project |
03-09-2012, 05:04 AM
You could use the 20V SILVERTOP tensioner or 16v one but I think you have to change the oil pump too...
They are pretty different and the blaktop pump doesn't have the threaded hole for the tensioner bearing. 16v / 20v silvertop: ![]() Blacktop: ![]()
03-09-2012, 09:33 AM
| 4AGE 20V BT timing belt and tensioner | |||
| 20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 16,448 |
| Rear Seat Belt Question | sleepercivic | 5 | 11,633 |
06-29-2017 09:30 PM Last Post: banpei |
| 4agze timing | leon205gti | 11 | 16,425 |
04-07-2017 03:10 AM Last Post: jondee86 |
| Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 6,477 |
| [Tutorial Video] Setting 4A-GE Ignition Timing | Homem Bomba | 0 | 6,549 |
![AEU86 AE86 - 4AGE 20V BT timing belt and tensioner [Image: AEU86 AE86 - 4AGE 20V BT timing belt and tensioner]](http://i30.tinypic.com/v5cy0x.jpg)
![AEU86 AE86 - 4AGE 20V BT timing belt and tensioner [Image: AEU86 AE86 - 4AGE 20V BT timing belt and tensioner]](http://i202.photobucket.com/albums/aa153/fchanz/BT%20OILPUMP/100_1538.jpg)
