4AGE 16v N/A project
11-16-2008, 10:40 AM
- Head of bigport
- Bottom end of 4AGZE
- New bearing rods (new parts where it needed when a bottom end is "opened")
- TODA RACING pistons 82mm 20 pin
- TODA RACING rings of pistons
- TODA RACING cam gears adjustable
- TODA RACING camshafts 272 10,3 lift
- TODA RACING valve springs
- TODA RACING timing belt
- Cylinder head porting
- TOYOTA 1SZFE underbucket shims
- TOYOTA OEM 4AGE bigport head gasket
- TOYOTA Idler spring tension (the parts for timing belt)
- TOYOTA 4AGE of CELICA adapter/bracket oil filter for oil cooler
- TRD oil filter
- TRD (DENSO IK20) iridium power spark plugs
- TRD plugwires
- TOYOTA OEM exhaust head (needs replacement)
- CR 11,3:1
[Image: AEU86 AE86 - 4AGE 16v N/A project][Image: AEU86 AE86 - 4AGE 16v N/A project][Image: AEU86 AE86 - 4AGE 16v N/A project][Image: AEU86 AE86 - 4AGE 16v N/A project][Image: AEU86 AE86 - 4AGE 16v N/A project]
I hope next Saturday to start the engine. But ll start with stock ecu? Can i use it with safety? ok not 8000rpm but 3000-4000 ll be ok?
I know that the right is to be a standalone but i ll buy a plug&play. Emanage of Greddy ll be fine?
Thx a lot
Bad bad english
**COROLLA EE80 - 4AGE 124HP**
11-16-2008, 04:32 PM
I don't think it will idle with those settings. And it might run too rich.
You're running too much lift for the stock ECU to cope with it! I would run megasquirt with that setting. I don't think Greddy E-manage will do. Ask ZDoman.
Good luck!
11-16-2008, 11:48 PM
The stock ECU should be able to get the engine running but most probably it'll sound like a ported Wankel engine and probably smell like one, too (unburnt fuel in the exhaust). You'd need to adjust the idle pretty high to keep it from stalling, though - around 1500-2000rpm.
The camshafts have really steep ramps so the manifold vacuum changes very sharply on low RPMs. The ECU can't keep up with it so it'll be constantly jumping between rich and lean. The E-Manage Ultimate doesn't really help as it uses the same MAP signal - just applies its own fuel maps. To work around this problem, you'd need an ECU which can apply Alpha-N mapping (throttle position) instead of the normal speed-density (MAP) for fueling. A Megasquirt can do this and also offers a possibility for a hybrid Alpha-N which allows you to use TPS for low revs and transition to MAP in the upper RPM range. This should make lumpy cams a bit more bearable (and MOTable) in street use.
11-17-2008, 08:15 AM
Thx for the answers
Is the "problem" caused from the high lift(10,3) or from the CR 11,3:1 too? If i replace the cams with lower lift (9,3) ll be the same problem? I want to avoid the buy of a standalone.
Thx a lot again
11-17-2008, 08:28 AM
cams are the biggest "enemy" idle will be bad. I did tryed firehawk cams on my 4agze engine and it was badd with emanage, then i sold the cams to him. Could not drive them and there was very big pressure changes AND my z was AFM model map should be worst than that.
Tomi
11-17-2008, 10:43 AM
So the solution is to change the camshaft with 9,0 or better 8.1 lift? but i have to change the adgusting of the head. hmmm!
Thx guys
11-17-2008, 10:58 AM
272 cams near 9mm lift i have seen used on 4age engines road use. We have thease N-group ecu what those cams need to work ok (liftet rpm, little different fuel/spark map mayby some more). i assume that greddy emanage, litle bigger injectors. It mayd work ok whit std ecu
11-18-2008, 10:42 AM
I doubt if it will work. Maybe the engine will start, but not properly..
I don't advise you to use it for a long time especially not for breaking in.
Emanage could be a problem on this setup, as we wasn't able to get it working on the MAP sensored AE86... I think your engine control is the same so you should look after a standalone system like MS.
11-18-2008, 10:52 AM
Yeah mine 4agze was afm and that does work better whit big cams.
11-22-2008, 09:25 AM
Which parts have i to buy for MS? (unit, harness, sensors ect)
http://www.diyautotune.com/
I need help because i dont know what exactly i need.
  CXRacing AE86 Corolla Top Mount T3 Turbo 4AGE 16V Build CXRacing 5 12,928 07-12-2012 02:03 PM
Last Post: mc68
