4AGE 16V Timing Issue
01-12-2012, 05:34 AM
Dear all, due to my 4A minor shaking during ideal. so check timing
with timing light and found out that it as 20deg. it high then i thought
but the engine still shaking. i lower the timing but engine die after
lower it. did any one can assist me on this issue.
thanks.
01-12-2012, 06:51 AM
This thread should help, http://www.aeu86.org/viewtopic/4age-igni...ght=timing
01-13-2012, 02:41 AM
What's the compression????
The Ignition timing doesn't change by itself, it's either 10's of thousands of kilometers of wear for a very minor change or someone F'd with it.
It will not change enough by itself to cause a rough idle in a short period of time, it takes years, not days weeks or months.
You've got some other problem.
So what!
01-14-2012, 03:46 PM
look at bean banit´s link!
If that fails I´d have a look at compression.
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
02-04-2012, 06:53 AM
thanks guy. i still try to figure how to solve this issue.
02-04-2012, 09:07 AM
what RPM is it idling at??
  PWR light issue and no brake fluid after winter storage magpie 10 7,865 05-25-2023 08:09 AM
  Fuel pump issue DJexor 11 11,538 04-29-2022 05:45 AM
  Cusco Powerball Headers on a NA 4AGE 16V? JDMitch 11 27,111 05-01-2021 10:09 PM
  Clutch Issue Deaty 8 8,081 04-09-2021 10:26 PM
Last Post: Nakilad
  5th gear issue r.ave 1 4,920 03-14-2021 08:52 PM
