4A's Engine's
09-10-2004, 11:48 AM
4A's Engine's
The 4A-GE has many conversions
4A = the name of the lower block GE = the type and head name 4A-FE FE = the economic version 4A-GZE same as the 4age except the Z stand for supercharger (used in mr2 AW11, Toyota Corolla Levin - Trueno AE92 AE101) 4A-GTE T Stands for turbo this engine was never originally build it has been a conversion of a gze or ge with a turbo on it 4age is an 16 V engine later the 4age got a 20V younger brother in 2 verisons AE101 silvertop 20V 160hp in the engine AE111 Blacktop 20V 165-170hp in the engine this version has variable valve timing to compete with Honda V-tec engines. the 4age is in 2 difrent lower blocks A 3 ribt block and a 7 ribt one the 7 ribt one comes in 2 versions one with oilsquirters and one without them. with oilsquirters is build since 1991 the 7 ribs is build since 1987. 3 ribs is build since 1982 and released in 1983. The ribs are for a stronger lower block and not for cooling as one might think Check what you want everything has its advantages. Turbo and supercharger a great for more power and sprints etc. NA is perfect for drifting high revving Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
09-10-2004, 11:57 AM
4A's Engine's
Both the 20V engines are only good for around 140bhp. The valve timing system is no match for the VTEC system. Honda has patented everything thats even similar.
09-10-2004, 01:50 PM
4A's Engine's
nah then can put out more because there held in same like a limiter also the standard jap ecu's are limitet at 185 kmh
:-( the engine doesn't run on its full potential seen one run at 190 Hp at the wheels how fun is that regards Lennert Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
| toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 11,167 |
| Need engine,any engine | Apolan | 25 | 28,745 |
10-29-2006 06:55 PM Last Post: ZaX |
