4A-GTE 7-rib smallport
05-22-2017, 09:42 AM
Hey!
Researched the posibility to turbo a smallport but all the threads I found were about bigports or GZE engines. The higher compression of my smallport surely must make a difference.
I'm toying with the idea of putting a small turbo​ on my 4age (maybe 6-8 psi boost). I read that 7m-ge/gte injectors fit the 4age and provide more fuel than stock injectors. Will the stock smallport ECU handle the bigger injectors or would I need a piggyback/standalone?
Would the engine hold up with a small amount of boost or is it not an option on a stock smallport?
Any info is appreciated! Smile
05-22-2017, 12:44 PM (This post was last modified: 05-22-2017 12:45 PM by d3nso.)
Everything you found about turbo conversion of bigports can applied to smallports. The higher CR makes a difference but if your tune is done right isn't it much of a problem.
This leads to the ECU. The stock ECU doesn't like boost so piggyback or standalone ECU would be needed. I would go standalone, not a fan of half assed piggyback setups Wink
7MGTE injectors do work like every others which are +300cc.
Daily Beater: Civic EG5
Work in progress Car: AE86
05-22-2017, 07:30 PM (This post was last modified: 05-22-2017 07:31 PM by nyberrg.)
(05-22-2017 12:44 PM)d3nso Wrote:  Everything you found about turbo conversion of bigports can applied to smallports. The higher CR makes a difference but if your tune is done right isn't it much of a problem.
What about the stock ECU would be the issue? I know it's pretty stupid, but I want to do a turbo as kind of a budget upgrade!
05-22-2017, 10:47 PM
The stock ECU isn't designed to handle positive manifold pressure nor to handle such big injectors thats why you should go the standalone route. And yes doing a Turbo setup on a budget is not the best idea Wink
05-23-2017, 03:29 PM
(05-22-2017 10:47 PM)d3nso Wrote:  The stock ECU isn't designed to handle positive manifold pressure nor to handle such big injectors thats why you should go the standalone route. And yes doing a Turbo setup on a budget is not the best idea Wink
It is probably the most cost effective way to gain power though!
05-24-2017, 09:24 PM
Don't bother with stock ecu and anything but small upgrades. At the very least get a Megasquirt or even better a ECU Master. Nothing is cheap when you're tuning Wink
  Wanted: 3-rib engine repair manual Ivan141 6 5,022 09-09-2022 07:46 PM
Last Post: oldeskewltoy
  Smallport coil totta Crolla 2 3,367 08-12-2022 11:03 AM
Last Post: totta Crolla
  Smallport inlet manifold totta Crolla 6 5,587 01-17-2022 05:14 PM
  Smallport Fuel Rail Alex170984 2 5,974 11-19-2016 08:44 PM
Last Post: Alex170984
  Smallport Head swap Alex170984 9 11,953 06-09-2016 12:11 PM
Last Post: ZDoman
