4A-GE with 264º HKS Camshafts running very rich
11-21-2006, 11:45 PM
http://www.jmross.freeserve.co.uk/obj21geo1pg1p3.jpg
and here you can see it , lower load = more advance /Skassa Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
11-22-2006, 12:07 AM
Denmark Wrote:http://www.jmross.freeserve.co.uk/obj21geo1pg1p3.jpg Sorry I remembered wrong.In this case you should listen only for knocking, you know leaner AFR causes more possibility for detonation. |
11-22-2006, 12:21 AM
So this should work for apardal?
This is how I knew it - going lean is good, going rich is bad with SAFC. But how about a fuel pressure regulator + SAFC for setting lean?
"..el camino's aren't supposed to make sense, craziness is what makes the world go around." - Car & Driver, 1984 |
11-22-2006, 02:13 AM
Well, you've managed to mess my mind up! Now I'm even more confused.
What I know is: About compression - I have longer duration cams, shaved head and trd head gasket, so compression values are fairly stock which I think is Ok. About AFR - Longer duration cams means that the map sensor will read lower pressure in the intake manifold. The ECU thinks the engine is on heavier load and will respond with later ignition and longer injection which makes it run richer. Running too rich will make the mixture burn slower, hence losing power. (all these sentences are suppositions of mine, I'm no expert on this matter so please correct me if I'm wrong) Solutions: - The CO (lean/rich) screw only acts below 3600 rpm so it won't make any difference in high rpm's. - Having a fuel pressure regulator or smaller injectors will act in all rpm range proportionally and that's not the perfect solution. I think I'll need differential changes throughout the rpm range. - The SAFC seems like the best solution, although I do not quite understand what Zdoman is stating to be the downside of going with a piggy back. Recently I've found that the Greddy E-Manage Unit is quite complete... but I don't know anyone who has experienced it with 4A-GE's. I would also like to change my rev limit, since these cams need a little more rpm... but megasquirt is a long way to go and I don't know other solutions that may fit my requirements. Thank you very much for your interest Best regards |
11-24-2006, 04:04 PM
Splitted the VEMS discussion to another topic
12-07-2006, 09:22 PM
Running rich? JUICE UP THE TIMING!
12-07-2006, 10:18 PM
what do you mean by this ?
AE86 FANATIC!!! |
12-07-2006, 10:58 PM
alimonos Wrote:what do you mean by this ?or just lower the fuel pressure a little bit to get it leaner,and then see how it reacts to this ![]() sr86 completed!!........漂うことのマスター!!!! |
12-07-2006, 11:03 PM
alimonos Wrote:what do you mean by this ? If you are running rich at the timing that you are currently running, then advancing the timing should net you more power and the extra fuel that you have right now should compensate. I suggest to advance the timing until you hear slight pinging and then back it off a couple of degrees. g |
12-07-2006, 11:57 PM
You mean both in and ex cams ?
AE86 FANATIC!!! |
| No idle below 2000 rpm rich running | Steller Engineering | 3 | 3,428 |
| Running issues | sam3007 | 6 | 5,379 |
| HKS valve springs | totta Crolla | 3 | 4,286 |
| 4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 11,346 |
| HKS Legal exhaust | Nakilad | 2 | 6,767 |
07-31-2019 10:00 AM Last Post: Nakilad |
I remembered wrong.
![AEU86 AE86 - 4A-GE with 264º HKS Camshaf... very rich [Image: AEU86 AE86 - 4A-GE with 264º HKS Camshaf... very rich]](http://www.driftparts.nl/Eric/Spaanbanaan.jpg)
