4A-GE head work
10-31-2004, 12:34 PM
4A-GE head work
Rikard,
how did you pull out the crankshaft seal? Did you have to dismant also the oil pump body? How did you put the new one in? Regards Andrej |
10-31-2004, 12:36 PM
4A-GE head work
Just curious:
Are the prices indicated (17 eur for pulley and 5 eur dowel) for new toyota parts? Andrej |
10-31-2004, 01:34 PM
4A-GE head work
Plex Wrote:no way? hahahaha Even then the startertrick may fail. I've seen it fail on robokill's yellow coupe. Most of us have the old non-reduction starters, and the starter engine just stopped dead in it's tracks when we tried the starter trick. An airwrench didnt do the trick either. We had to get the pulley bolt on that car off by using huge locking grips on the smaller part of the pulley and a wrench+breakerbar. Just because something works most of the time doesnt mean it's a solution that always works. Now then, anyone have any other ideas for getting the timing belt cog of the crankshaft without having to use a grinder? "Sometimes giving up isn't the answer we're looking for, but its the only answer we have" |
10-31-2004, 01:43 PM
4A-GE head work
dreja Wrote:Rikard,I took it out with a small flathead screwdriver and then put in the new one with a small hammer hitting it softly all the way around. Did not have to remove the oilpump as i didn't pull the sump
4A-GE head work
dreja Wrote:Just curious:Yes they were toyota parts. |
10-31-2004, 07:53 PM
4A-GE head work
Tnx for the answer.
When my car is back from body restauration& repaint I'll have to change the same oil seal as you, because I have some oil leak. I hope that only this seal is leaking and not also the camshaft oil seals. Andrej |
10-31-2004, 08:09 PM
4A-GE head work
Quote:no way? hahahaha Even then the startertrick may fail. I've seen it fail on robokill's yellow coupe. Most of us have the old non-reduction starters, and the starter engine just stopped dead in it's tracks when we tried the starter trick. An airwrench didnt do the trick either. We had to get the pulley bolt on that car off by using huge locking grips on the smaller part of the pulley and a wrench+breakerbar. Just because something works most of the time doesnt mean it's a solution that always works. Now then, anyone have any other ideas for getting the timing belt cog of the crankshaft without having to use a grinder? FABRICA MI DIEM, PVNC! |
10-31-2004, 09:14 PM
4A-GE head work
quote] Now then, anyone have any other ideas for getting the timing belt cog of the crankshaft without having to use a grinder?[/quote]
I don't think there is another way, I tried everything before I had to grind it off! |
10-31-2004, 09:15 PM
4A-GE head work
dreja Wrote:Tnx for the answer.the camshaft oil seals can be done the same way as the crankshaft!
10-31-2004, 10:22 PM
4A-GE head work
Ivan141 Wrote:Quote:no way? hahahaha Thats crazy... your euro cars are whack or something haha (jk)I've never seen, or heard about that fail... Sorry for the mis-information I suppose "Sometimes giving up isn't the answer we're looking for, but its the only answer we have" |
| How seatbelt rails work? | FanIsHere | 2 | 6,081 |
05-18-2016 09:52 AM Last Post: Bean |
| my last work , Dentist needed | filh | 5 | 7,495 |
03-29-2013 07:47 AM Last Post: assassin10000 |
| How does the 4age AFM system work? | heshan | 22 | 30,344 |
12-20-2012 05:01 AM Last Post: heshan |
| my tvis doesnt work... | daywalker | 30 | 56,579 |
02-19-2012 01:25 PM Last Post: ZDoman |
| Work equip 01 max offset?? | stalker | 5 | 11,096 |
08-23-2011 03:09 AM Last Post: Lewy |
(jk)
