4A-GE + CARB
01-19-2005, 11:16 AM
4A-GE + CARB
Anyone got idea about this setup?
I've found carbs from Kawasaki ZX-9R, 10 000km. Bike is destroyed.
Carbs are keihin G314 AKKL with 40mm inner diameter.
We've calculated that flow on 900ccm engine on 14k rpm is same as 4a-ge small port on 6,6k rpm so it should be ideal in terms of sizing.
I might try this setup, but the bike-guy says i have to run'em with airbox on. Since i would like to run them with trumpets/KN filters is there any problem with that, since these carbs need vacuum to work properly.
PLEASE SOME OPINIONS since it's kinda urgent.
I need to buy or return these babies.
01-19-2005, 11:25 AM
4A-GE + CARB
nice thoughts you have! where do these carbs need vacuum??? (afaik this equeal-pressure thing is made internaly. no need for airbox ...)
01-19-2005, 11:56 AM
4A-GE + CARB
There will be no problem with vacuums :-)
But adapter seems to be big2smallport - I think that you will need additional (or new) one.
01-19-2005, 01:18 PM
4A-GE + CARB
Zax,
take a quick look at the carbs that Stage One offer for the 4AGE. I guess this will give you an idea about jet sizes etc.
I can do you a deal on a nice set of K&N filters as the ones I had on my car are no longer required. going cheap.
Regards Ian.
[Image: AEU86 AE86 - 4A-GE + CARB]
01-20-2005, 08:15 PM
4A-GE + CARB
you guys are all wrong -' These are VACUM carbs - they need preassurized airbox
K
01-21-2005, 05:18 PM
4A-GE + CARB
Zax better not try this i think getting them to work is not managable for what you want with it.
What would your ecu do ???
01-21-2005, 06:57 PM
4A-GE + CARB
I gave up on these.
To much problems to make them work properly.
01-21-2005, 09:43 PM
4A-GE + CARB
wy not a 2 webber carb's ?Whit a 8v bobine (sorry for my bad english)
Yaris 1.3 xp9
Yaris 1.0 p1
Mercedes citan
weekend driver 1985 AE86
01-22-2005, 10:51 PM
4A-GE + CARB
my friend Allen has some mikuni carbs from a motorcycle that would work, as he was going to do this originally... I'm sure he'd be willing to ship to you contact him if you want @ hachiroku.net... his username is Allen
01-23-2005, 02:09 PM
4A-GE + CARB
2 plex: tnx, but i must concentrate on my bodywork before doing these silly power upgrades. Smile
  Carb question please help MIGGZFSU 3 6,931 03-29-2017 03:06 PM
Last Post: MIGGZFSU
  Changing distributor when carb 4age izanagi 14 21,732 07-04-2016 03:27 PM
Last Post: Uzelac
  Carb conversion but what is this and how ? Allexz 5 11,164 05-24-2016 08:48 AM
Last Post: Allexz
  Mikuni carb help just wont balance megabob 3 7,077 01-01-2013 10:32 PM
Last Post: allencr
  Carb'd 4AGE on Hyperpak ignition no spark problem 4AGE FORD 12 28,204 01-22-2011 11:03 PM
Last Post: 4AGE FORD
