4 age smallport cams
07-24-2007, 06:25 PM
Here´s another one who likes to change his cams. Sorry to bother all you guys with another cam question Undecided
Small port 4 age with throttle bodies. Omex ECU. 280cc injectors.
Now using standard cams in and exhaust side 232 degrees and 7.1 mm lift. would like to keep it a non interferance engine too
Not looking for peak power but midrange. Don not want to loose lower end torque too much.256 / 264 something like that. but lift ? it should idle "normal"...
Does anybody has any experiences with catcams.be ?
cheers
Jos
http://www.heerlijklimburg.nl
07-25-2007, 08:22 AM
ive heard blue top cams make some difference to power in a smallport. have to be re-shimmed though.
07-26-2007, 07:23 PM
thank you for your tip.
nice country to be livin :wink:
07-26-2007, 08:43 PM
not so much in winter. summers are pretty nice though Cool
dancke.
07-26-2007, 09:17 PM
catcams are ok haven't felt it yet with itb's (soon will building an engine) But with standard intake the high lift kill the lower rpm.
10-18-2007, 07:46 AM
Dear Robokill,
Have you made any progress yet ?
Since the 4age is a non interferance engine I want to keep it that way, so what cams are max. to keep it non interferance ?
( would like to change them before it gets dyno'd maybe, to take some more advantage of the tb's without losing to much on lower rpm )
regards
Jos
  Smallport coil totta Crolla 2 3,351 08-12-2022 11:03 AM
Last Post: totta Crolla
  Smallport inlet manifold totta Crolla 6 5,575 01-17-2022 05:14 PM
  Starting problems 4-AGE kouki Hanzo 3 4,540 08-31-2021 06:20 PM
  Shim size for AM cams kazi 4 7,319 12-18-2017 05:34 PM
  4A-GTE 7-rib smallport nyberrg 5 8,517 05-24-2017 09:24 PM
Last Post: krullibull
