3sgte in an ae86
12-05-2006, 02:24 PM
3sgte in an ae86
has any one ever fitted a TOYOTA MR2 3SGTE TURBO ENGINE into an ae86?
if so what was needed and what was done about the inletmanifold
also what gearbox if any is a straight fit?
wot kinna power do these engines put out?
12-05-2006, 03:22 PM
3sgte in an ae86
Yup. Turborolla put one in his rolla:
http://www.aeu86.org/viewtopic.php?t=1198
I thought he used a Supra gearbox and it was not a streight fit. Tongue
[Image: AEU86 AE86 - 3sgte in an ae86]
12-05-2006, 03:37 PM
3sgte in an ae86
Gearbox is a problem..basically you have two options. The easiest option for the swap, but most difficult to find is sourcing a JDM soarer/cressida/some big car but dunno which 3SGE halfcut. There was one RWD car that got the 3SGE as standard. That would give you RWD motormounts, W-series tranny bellhousing and RWD Oilpan.
Otherwise it becomes a big adventure to drop one in..imho not worth the bother. Looking at the CA18DET in our AE86, that engine is close to a bolt in swap. All thats needed is a small extension of the motormount plates. Its already fully setup for RWD use. SR20DET would be similar. Horsepower very similar to the 3SGTE.
12-05-2006, 05:52 PM
3sgte in an ae86
I think you're refering to the Japanese Altezza ( RS200 ) which has indeed a 3SGE. Too bad it never got sold here. Crying
12-05-2006, 05:54 PM
3sgte in an ae86
i've heard there where some other cars which had the 1S/2S in RWD setup, those had T50 boxes (i've heard...). Turborolla uses a custom bellhousing (made from 3S and W58?? bellhousings)
12-05-2006, 06:06 PM
3sgte in an ae86
You just need to find a RWD Corolla/Carina C-engine (diesel) bellhousing, screw it to W-series gearbox and nothing else. It fits straight to S-series engine :wink:
12-05-2006, 06:49 PM
3sgte in an ae86
The Doctor Wrote:i've heard there where some other cars which had the 1S/2S in RWD setup, those had T50 boxes (i've heard...). Turborolla uses a custom bellhousing (made from 3S and W58?? bellhousings)
According to this site it must be the ST141 Corona:
http://ourworld.compuserve.com/homepages...gcodes.htm
12-06-2006, 11:49 AM
3sgte in an ae86
S.K. Wrote:You just need to find a RWD Corolla/Carina C-engine (diesel) bellhousing, screw it to W-series gearbox and nothing else. It fits straight to S-series engine :wink:
Are you 100% sure ?
12-06-2006, 01:41 PM
3sgte in an ae86
Are you 100% sure ?
Yes, I´m sure. Here in Finland is 2 "SE70" used 1C (CE70 or CA60) bellhousing and W-gearbox.
12-06-2006, 01:45 PM
3sgte in an ae86
Many thanks !
  looking for a billet 3sgte or ge cranks Celica RA45 1 4,266 06-26-2011 05:45 AM
Last Post: Celica RA45
  3sgte questions. Mr_Efficiency 5 8,534 03-04-2008 12:35 PM
Last Post: The Doctor
  3sgte or 4agze surfingdrums 12 17,124 08-11-2006 12:56 PM
Last Post: NoHachi
