3sge from m2 in ae86
12-23-2010, 01:25 AM
can i put 3sge (gen 2) from MR2 into ae86 ? what gearbox ?
I saw people did alteza 3sge in hachi .. but i didn't find anything about mr2 3sge into ae86
Please help Big Grin
12-23-2010, 03:01 AM
its a bit difficult mod, but possible. look it up in google!
you have to put the engine in tilted to the right side by 20degrees to fit it under the hood, modify the oil pan, cut and relocate the throttle body to the front side of the induction box. you have to use a W5x series gearbpx, possibly w55, w57 or w58 and make or search and buy a custom bellhousing inbetween. also there may be some firewall space problems occur as well.
12-23-2010, 06:54 AM
diesel corollas "*e70" serie have correct bellhouse whit w50 gearbox.. bolt on..
you need to cut and weld or put different intake to car. but 3sge fits nice to rwd corollas..
12-23-2010, 10:56 AM
this is relevant to my interests! plz moar!
12-23-2010, 12:00 PM
Lajoosh Wrote:this is relevant to my interests! plz moar!
Vouch.
plz moar !
12-23-2010, 10:57 PM
Also the Carina CA60 diesel (1C engine) will fit to the W bellhousing.
I found this list some time ago with our NZ friends:
1C 2C 3C
1S 2S 3S 4S 5S
1VZ 2VZ 3VZ 4VZ 5VZ
1MZ 2MZ 3MZ
1GR 2GR 3GR 4GR
http://forums.toyspeed.org.nz/viewtopic.php?t=73257
[Image: AEU86 AE86 - 3sge from m2 in ae86]
12-23-2010, 11:54 PM
banpei Wrote:Also the Carina CA60 diesel (1C engine) will fit to the W bellhousing.
1C 2C 3C
1S 2S 3S 4S 5S
1VZ 2VZ 3VZ 4VZ 5VZ
1MZ 2MZ 3MZ
1GR 2GR 3GR 4GR
ca60 gearbox can hold the power of 3sge - 3sgte ??
01-02-2011, 03:04 PM
there is a lot of 3sge conversion information here:
http://www.ae86drivingclub.com.au/forums...-KE-thread
My website:
S-86.com
01-02-2011, 09:52 PM
Xerius Wrote:ca60 gearbox can hold the power of 3sge - 3sgte ??
Depends on whether it has a W50 or W55 behind the bellhousing.
BTW: found another interesting source:
Quote:S to W
Factory fitted behind jdm 1S and 2S engines in SA6# celica, ST14# corona with a W55. these need to be modified to fit a 3S(GE) block because the gearbox input shaft does not reach the spigot bearing. The diesel C series engine 1C/2C have an identical bellhousing with a W box behind it. But interestingly most commonly found in vans with a 1C or 2C engine and G series gearbox (G52, G55) which has same bolt pattern as the supra W55 box. Other bellhousings have been known to be adapted like the 2Y/3Y to W bellhousing by slotting some holes.
Sounds like you need to source a Hi-Ace diesel with a 1C or 2C engine and a G series gearbox. Wink
01-20-2011, 12:06 PM
There's a part number for the bell housing on the net somewhere you can still order them new from the dealer
- Fuzzy
  Toyota KE70 3SGE Beams Swap - Axle reliability cke70 15 30,108 04-13-2014 12:49 PM
Last Post: Celica RA45
  f20c vs 3sge Petros AE86 7 15,012 02-26-2012 12:29 PM
Last Post: roiz86
  put a head of Celica 2.0 GT ST162 16v (3SGE) in mine 4a-ge Emanuelae86 4 5,793 10-01-2006 06:54 PM
Last Post: Corey
