3 piece wheels
10-06-2008, 06:30 PM
3 piece wheels
So i picked up a set of 3 piece 13" graku wheels yesterday.
They are not bling and shiney anymore and i like to have them cleaned and dish polished etc. Now can i just undo all bolts, clean the lot and put it back together myself? Or is this a specialists job? |
10-06-2008, 07:03 PM
3 piece wheels
centers are pressed in. You can get the bolts out but mostly the centers wont come loose that easy.
10-06-2008, 07:06 PM
3 piece wheels
There seems to be no pressing... the centers just sit in between of the 2 rim pieces...
http://img150.imageshack.us/my.php?image...072de3.jpg Rokuichi Power !! _________________________________________ Toyota Starlet KP61 2.0 vtec |
10-06-2008, 08:03 PM
3 piece wheels
i think its exactly like mine only mounted from the rear, so not between. Still think its pressed in...
10-06-2008, 08:15 PM
3 piece wheels
The rear looks the same..
Only nuts instead of bolts. Rokuichi Power !! _________________________________________ Toyota Starlet KP61 2.0 vtec |
10-06-2008, 08:22 PM
3 piece wheels
This is how it is bolted together.
10-06-2008, 09:19 PM
3 piece wheels
exactly, there is a front ring, a plate wich is the center of the wheel and a back ring.
couple of nuts and bolts to hold it together. |
10-06-2008, 11:00 PM
3 piece wheels
the problem is the sealing between the 2 halves.
all my wheels are 3 piece design, but all of them are welded, i think because of air thighteness (spelling? ) problems.
10-06-2008, 11:20 PM
3 piece wheels
How about a liquid gasket?
10-07-2008, 08:01 AM
3 piece wheels
AFAIK they are sealed with a urethane sealer/adhesive. If you take
them apart you will have to clean off the old adhesive and remake the joins. If you have a mag wheel repairer in your town, he should be able to advise you. Cheers... jondee86 |
| One-piece driveshaft | drako323 | 18 | 31,362 |
03-01-2010 06:10 PM Last Post: NoHachi |
) problems.
