20v mains & big end bearing
12-22-2016, 12:50 AM
Hi everyone,
I'm replacing the mains & big end bearings according to the FMS. I did the sum with the 5 digits and it gets me the number: 22233 for the mains bearings.
As I guess, one digit is the size for one journal.
My question is: where goes my first size (2)? The front (oil pump side) or the rear (rear oil seal side) ?
Same question with the 4 digits for the big ends bearings (1222). Does it start at the first cylinder (front of the engine) or the rear ?
Thanks for your help.
12-22-2016, 08:45 AM
lesson i learned dont go with the numbers but measure!!
12-22-2016, 01:23 PM
izanagi, like ditn said.... Don't go for the numbers. They're OK for reference but measure carefully each one.
You have two options here.
If your engine is still STD you can buy some King Bearings std ones, and by wear they will match the measurements.
OR
If your engine is still STD you can go for the numbers (with measurement taken carefully)
regards
12-22-2016, 03:42 PM
(12-22-2016 01:23 PM)pack Wrote:  izanagi, like ditn said.... Don't go for the numbers. They're OK for reference but measure carefully each one.
OR
regards
I wanted to go for ACL bearings. What do you think ?
12-22-2016, 05:00 PM
Actually, the ACL bearings madness is almost gone... And King Bearings are being used all over with nice results.
I've bought a few for 4AGE's and B16/B18 with sweet results...
Keep in mind that the bearing set from ACL/KING STD will not match any numbers you have. They are all the same size, and they work by wear.
When you fit them, they will gradually wear and match their clearance.
12-22-2016, 10:49 PM
King Bearings seams to be cheaper also
12-23-2016, 11:40 AM
And they're pretty good...... Wink
12-24-2016, 11:26 PM
If you are using the OEM sizing... the numbers begin at the front of the block......
Dan -
12-25-2016, 11:38 AM
I've used several King bearings and all of them died in about 1000kms, I really don't get how people having good reliability with them. Or everyone uses the King Racing series? The normal ones I don't suggest, the racing series I never tried.
I had good results with Toyota originals, ACL Race, and NDC (sold in europe under Kolbenschmidt name) also the Taiho is a good japanese brand, I think the Toyota oem ones are also Taiho's. They are sold as Glyco in Europe.
12-26-2016, 12:42 PM
When i talk about King bearings yeah they are King Racing series!
  4AGE Big port head failure Blaze0010 3 480 01-23-2026 03:35 PM
Last Post: totta Crolla
  Big wheel problems gh0st 16 13,156 11-15-2021 10:51 PM
Last Post: gh0st
  Front big brake kit DidiDex 14 22,526 10-24-2016 09:29 AM
Last Post: FanIsHere
  Wheel Bearing Temperature Super86 5 8,544 09-29-2014 12:26 AM
Last Post: jondee86
  Machining Pistons to run 20v head... And FCR's on a 20v? PazzaAE86 2 6,388 09-15-2013 01:08 AM
Last Post: jondee86
