20v coolant problem
07-01-2013, 09:27 AM
20v coolant problem
Hi,
I recently got a 20v blacktop installed with an sq-engineering kit for cooling. Every 5-10 minutes or so the coolant temperature rises till the meter can't go further and then suddenly drops back to normal in half a second. We've tried to bleed the radiator to let the pockets of air out, but it seemed this wasn't the problem. Now we are replacing the sensor ..somehow I think this won't solve it (the sensor was new and a part of the kit).
any ideas what else it could be? Still some air stuck somehow?
thanks
Edit: it's not related to revving it seems to happen completely at random
07-01-2013, 10:50 AM
20v coolant problem
Have you checked the thermostat? I would guess it's either air trapped in there or the thermostat waitintg too long to open.
07-01-2013, 10:56 AM
20v coolant problem
Your instrument panel is faulty...Wink Mine is the same...
07-07-2013, 12:40 PM
20v coolant problem
Thank you for replying guys!
@ Ivan; we are going to replace it to be sure, at 25$ it's worth a try.
@walaki; I hope so Tongue but it worked fine with the 16v. How did you eventually find out it was the panel?
07-07-2013, 04:25 PM
20v coolant problem
Bravothreezero Wrote:Thank you for replying guys!
My electrician guy who built my 20V in found out that the water temperature gauge uses the same resistor as the fuel gauge and if that starts to go, the fuel level still shows accuratly, but the temp gauge becomes like this. I dont really know much about electricity, so dont count my words as this is written in stone, but at least he told me this and so far I dont have any reason not to believe him Big Grin Big Grin
07-15-2013, 02:44 PM
20v coolant problem
We replaced the thermostat, unfortunately nothing has changed Sad
any input is appreciated!
@ walaki
so in the end you got rid of the problem? We'll take a look at this next Smile
07-15-2013, 03:10 PM
20v coolant problem
Bravothreezero Wrote:We replaced the thermostat, unfortunately nothing has changed Sad
@ walaki
Nope, the dash is like this since I have the car, and I hear when the electric fan turns on and off, besides I have an oil temp gauge, so that helps Big Grin Big Grin
But now for the S14 instrument panel I bought a STACK water temp gauge, just to be sure Big Grin Big Grin
07-15-2013, 03:25 PM
20v coolant problem
Ah ok! Well if your electric guy didnt get around to fixing it then I highly doubt it will work for us Tongue an aftermarket gauge might give me some peace of mind too then
  AE86 Engine Coolant Temp Sensor izanagi 8 23,828 09-06-2014 05:47 PM
Last Post: izanagi
  bad coolant kawo 9 14,194 11-18-2013 07:43 PM
Last Post: Apsogos
  Machining Pistons to run 20v head... And FCR's on a 20v? PazzaAE86 2 6,576 09-15-2013 01:08 AM
Last Post: jondee86
  4agZe problem solved - 99% IC problem Okami 41 46,342 07-12-2012 04:49 PM
Last Post: Okami
  wich coolant? fax0815 7 20,134 09-30-2011 09:56 PM
Last Post: fax0815
