20v/16v lightweight pulley kits
11-07-2011, 12:43 PM
I was wondering if it is possible to use a full 16v pulley kit (crank, alternator and water pump) in a 20V engine (with 20v alternator and waterpump)
I'm under the impression that they cannot be mix matched (16v and 20v pulleys in the same engine) due to a misalignment between the crank and the alternator pulleys, but I am not sure if it is possible to use a complete kit from the 16v on 20v peripherals. Can anyone shed some light on this issue? Regards 86'LEVIN Track Project |
11-07-2011, 12:57 PM
My friend use a complete 16v pulley kit on his blacktop (just add a small spacer under the alternator pulley for the misalignment)
Sadly I don't have any picture |
11-07-2011, 01:14 PM
Thanks for the quick reply Project D.
Is your friend using only 20v components (alternator and waterpump)? If he is, then I guess I'll go with a 16v pulley kit. The spacer seems a easy enough mod that should not prevent the kit from performing correctly. :wink: Also, the crank pulley only uses one row, right? The second outer row shouldn't be necessary if your're not running AC/PS.
11-07-2011, 04:53 PM
Far as I know my friend use 20V components yes.
And single row crank pulley is perfect if you don't have AC/PS ![]() My friend use the red set, I use the gold one (on my 16v) ![]() (all parts made by aussifan, some with my very own specs )
11-08-2011, 01:53 PM
Thanks for the input Project D.
Do you remember what was the thickness of the spacer to make up for the misalignment? 86'LEVIN Track Project |
11-08-2011, 04:28 PM
I don't remember but it will not hard to sort it out.
By putting the 2 pulleys side by side you will be able to mesure the exact tickness you will need. |
11-08-2011, 04:54 PM
Right.
Will do as soon as I get them from aussiefan. Thanks!
| How to install 20V ITB on 16V head | Mr.komp | 7 | 14,963 |
| 4AGE overhaul kits/ Brian Crower stroker kit | Lt86 | 1 | 5,362 |
06-13-2015 06:53 PM Last Post: corolla4agze |
| 16V ECU pinout on 20v swap | pack | 2 | 7,484 |
06-12-2015 01:22 AM Last Post: pack |
| 20v block with 16v head and internals possible? | ditn | 3 | 8,915 |
08-12-2014 09:19 PM Last Post: ditn |
| 20v with 16v Water Relocation Kit | D.O | 9 | 18,996 |
06-12-2014 02:48 AM Last Post: jondee86 |
![AEU86 AE86 - 20v/16v lightweight pulley kits [Image: AEU86 AE86 - 20v/16v lightweight pulley kits]](http://a.imageshack.us/img682/9444/45229430644139724661054.jpg)
