20V ITB - what fuel rail and injectors ?
03-09-2010, 12:47 PM
Hi
When going to 20V 4AGE ITB's, what fuel rail and injectors should to be used ? - Standard 4AGE 16V rail and injectors - standard rail and more cc injectors - some other rail and injectors ? Is there anything else which have to be replaced when changing TVIS for ITB. I'm thinking "locally", just on intake. ECU, air sensor and other stuff are "of course".. Thanks |
03-09-2010, 01:34 PM
well injectrs depend on how much power you'll be running in the end. the 16V rail should to the trick
AE86 ex-daily |
03-09-2010, 02:24 PM
stock fuel rail and red top injectors will do the job
If youre aiming high power output (170+) use low impedance 310cc injectors with FPR IF Carlsberg made an AE86, then it would be propably the best car in the world... |
4AGE Injectors resistor | Blaze0010 | 4 | 1,685 |
01-27-2025 03:20 PM Last Post: Bean |
Trunk and fuel door cable | pack | 2 | 7,847 |
04-23-2018 11:01 PM Last Post: pack |
Smallport Fuel Rail | Alex170984 | 2 | 5,165 |
11-19-2016 08:44 PM Last Post: Alex170984 |
4A-GE 20V ITB bolt patterns | kjb | 7 | 13,395 |
02-27-2016 01:23 PM Last Post: kjb |
How to install 20V ITB on 16V head | Mr.komp | 7 | 13,048 |
