1984 ae86 no oil cooler
03-26-2008, 08:47 PM
is it easy to fit oil cooler to 1984 ae86 that has none
03-27-2008, 12:04 AM
yup ... just get the parts Tongue
oil filter sandwich adapter , the oil cooler and some pipes (rubber would be enough)
03-27-2008, 12:02 PM
i have a sump pan with bung, hoses and sandwich...all needed is a cooler
pm me for details
[Image: AEU86 AE86 - 1984 ae86 no oil cooler]
03-28-2008, 09:03 AM
OEM oil cooler is a by-pass type, that operates at near atmospheric
pressure, and returns oil to the sump. Just about any type of oil-resistant
hose or pipework will be fine.
Aftermarket coolers take oil from the filter to the cooler and back to the
filter. They are part of the engine lubrication system, and operate at the
same pressure as you read on your gauge. Your hoses, fittings and
pipework should be rated to operate at 10 bar or more without leaking.
If it is a full flow oil cooler, consider one with a thermostatic valve to
prevent the oil temperature dropping below 80 deg C.
Cheers... jondee86
  Mocal oil cooler & sandwitch plate ordered Gtsi-R 48 62,993 11-18-2022 02:19 PM
Last Post: FanIsHere
  Oil cooler totta Crolla 0 2,071 07-25-2021 03:25 PM
Last Post: totta Crolla
  Oil cooler kit izanagi 7 9,894 09-20-2016 11:13 AM
Last Post: harkes
  Permanent oil cooler vs thermostat Lt86 19 23,802 03-28-2015 06:54 PM
Last Post: Lt86
  trans oil, lsd oil change Apolan 9 19,289 10-01-2014 03:57 PM
