16V vs BEAMS
09-20-2016, 04:23 PM
16V vs BEAMS
Red car running the BEAMS, both have AZ6 gearboxes.
https://www.youtube.com/watch?v=FOCzImQIpmg
09-21-2016, 10:31 AM
16V vs BEAMS
Some nasty 16 reving like that above 8000 rpm Smile.
But as someone said in comments, 25%+ ccm must show Smile
09-21-2016, 12:15 PM
16V vs BEAMS
Would love to check the AZ6 fitment..... Wink
09-21-2016, 05:24 PM (This post was last modified: 09-21-2016 05:31 PM by oldeskewltoy.)
16V vs BEAMS
(09-20-2016 04:23 PM)harkes Wrote: [ -> ]Red car running the BEAMS, both have AZ6 gearboxes.
Exclamation
great!
Note the BEAMS car only really pulls on the 16V in 2nd, and/or 3rd, and higher...(huge assumption) - similar peak hp... but the extra volume (cc's) provides more torque throughout the entire rpm band.... this becomes more obvious as the gears are rowed
Dan -
09-22-2016, 04:47 AM (This post was last modified: 09-27-2016 12:52 AM by harkes.)
16V vs BEAMS
Obviously a high performance 2.0 should be able to beat even a highly tuned 1.6. The BEAMS owner claims 230hp and 230nm on a stock engine with ITB's and a costum tune...
My own experience is that he really starts pulling on me in 3rd. Further more, he doesn't hit the gas until I do so that give me a little head start.
09-22-2016, 10:23 AM
16V vs BEAMS
harkes..... i still want to see pictures of the AZ6 assembly! =D
09-22-2016, 10:24 AM
16V vs BEAMS
Both engines sound sweeeeet!
09-22-2016, 06:27 PM
16V vs BEAMS
What about the 16v setup?
09-27-2016, 12:51 AM (This post was last modified: 09-27-2016 01:00 AM by harkes.)
16V vs BEAMS
(09-21-2016 12:15 PM)pack Wrote: [ -> ]Would love to check the AZ6 fitment..... Wink
Hi Pack
Found an old picture that shows the essence of the swap. The in/out-put splines are different so I am running a LiteAce clutch friction plate. You can find AZ6's with the clutch release lever on either side.
(09-22-2016 06:27 PM)Andrax Wrote: [ -> ]What about the 16v setup?
Smallport with stock valves and valve springs, Silvertop ITB, F/A conrods and pistons (courtesy of Mr. Oldskewltoy), CR of 11.3, OMEX 500, ~300° 8.4 cams, full Martelius R1 exhaust, ported head
https://www.youtube.com/watch?v=JcAgVAElXQo
09-27-2016, 10:52 AM
16V vs BEAMS
Now we need Beams vs F20C.
I think I know which would win tbh, despite VTec. The Beams just has bags more torque.
With the same gearing ratios, you may get a tiny advantage by being able to rev so high with the F20, shift later, but the torque of the Beams would just pull on you.
  Purple beams hachi in NL banpei 2 9,014 05-10-2011 11:34 PM
Last Post: Aram
