10% faster ?
12-08-2010, 01:45 PM
10% faster ?
"wire up a small amp and some speakers to the knock sensor"
Tip of the month I never even considered that ! Just got to modify the water lines to fit the knock sensor back on. An analogue brain in a digital World |
12-08-2010, 09:31 PM
10% faster ?
totta Crolla Wrote:If I can make my '86 10% faster I reckon I can have a good competitive car in my class. Some have found that Driving School did more good then HP & weight reduction.
12-11-2010, 02:24 AM
10% faster ?
part of the reason I recommend selling all the old stuff is to get rid of 25 year old wiring @ the same time...
a BIG part of it is the newer stuff is so much more user friendly, the Freedom is legendary, but it seems to require a tuner from Japan Another place to get premium return on your old ECUs would be Yahoo Japan. Concerning ignition maps... I've got one that runs VERY well with 10.75 to 1 CR and 264 type cams....
12-12-2010, 01:28 AM
10% faster ?
My 4age it's running with Megasquirt and alpha-n mode.
@ oldeskewltoy What's your map % at idle, low acceleration, cruising and WOT? From your table I see very high advance happen to soon, but I'm above 11.3 to 1 CR with 288in/272ex/9mm and never tried to "map" the Megasquirt in MAP mode... (no enough map resolution with AE101 throttle bodies). |
01-02-2011, 02:58 PM
10% faster ?
likely to be hard to get but there is a lot of weight in the doors. Some fiberglass ones would help a lot
My website: S-86.com |
01-02-2011, 11:11 PM
10% faster ?
isac Wrote:@ oldeskewltoy to directly answer your questions: MAP @ idle 55-65 depending on load, MAP low throttle, 30-40, depending on load MAP @ WOT 90 to 100, depending on load MAP @ cruising 45-60, depending on load the ignition map was a collaborative affair - 3 tuners and I had a hand in its construction. The early timing advance was based on a map from a VERY reputable 4AGE experienced race shop.... ![]() A bit simple, but the timing is VERY aggressive My current fuel map is based on the following info.... ![]() the above info builds a base map for the system - based on 320CC low ohm injectors, and AFR targets(below)... ![]() here is the actual map.... % are based on the above 3 variables (injector specifics, injector volume, and AFR targets) ![]() The system is still "learning"... and I've had to fiddle with high rpm high vacuum situations, because I have the system NOT fueling when there is no TP angle present... this has caused some stumbling @ high rpm high vacuum (bottom right of fuel map) Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
01-02-2011, 11:45 PM
10% faster ?
"start" values from fuel map look very lean but not critical.
I prefer to start tuning from rich side. Quote:because I have the system NOT fueling when there is no TP angle present... this has caused some stumbling @ high rpm high vacuum (bottom right of fuel map) Just a thought, maybe you could remove some advance and increase fuel (richening AFR) in this area to keep walls wet during decelerating and prevent stumbling. |
01-03-2011, 02:40 PM
10% faster ?
all sorts of useful info here.
I may have found 1% already, whilst the car handled nicely I have since discovered the caster angles were wildly different each side. 3.2 degrees driver side and over 6 degrees passenger side. It seems the toe angles were adjusted to compensate. Needless to say it drives even better now An analogue brain in a digital World |
![AEU86 AE86 - 10% faster ? [Image: AEU86 AE86 - 10% faster ?]](http://i79.photobucket.com/albums/j143/oldeskewltoy/ignition%20maps/LoyC.jpg)
![AEU86 AE86 - 10% faster ? [Image: AEU86 AE86 - 10% faster ?]](http://i79.photobucket.com/albums/j143/oldeskewltoy/ignition%20maps/basemapinfo.jpg)
![AEU86 AE86 - 10% faster ? [Image: AEU86 AE86 - 10% faster ?]](http://i79.photobucket.com/albums/j143/oldeskewltoy/ignition%20maps/afrtargets2.jpg)
![AEU86 AE86 - 10% faster ? [Image: AEU86 AE86 - 10% faster ?]](http://i79.photobucket.com/albums/j143/oldeskewltoy/ignition%20maps/jan2011fuel.jpg)
