AE86 F20C swap - Radiator issue
02-06-2018, 06:36 PM
Hi All,
I'm currently committing to an F20C swap (S2000 Engine) into my AE86. The inlet and outlet are in different places for the 4AGE than they are in the F20 so I have to do something about the Radiator. S2000 4AGE Option A - Use High Performance AE86 radiator, have hardlines made up to account for the different inlet/outlet. Option B - Use High Performance AE86 radiator, have the inlet and outlet removed, plugged and the radiator flipped to have the right inlet and outlet welded on. Option C - Buy KOYO AE86 3SGE Swap. Images for comparison. What would you do? Thanks in advance. |
02-07-2018, 12:12 AM
I would go with C, it should make things a lot easier.
02-07-2018, 12:18 PM
Option D perhaps, have a custom alu one built.
Did that for my Sr20 into ae86 build and cost me about €600 incl 2 spal fans AE86 Levin |
02-07-2018, 05:14 PM
(02-07-2018 12:12 AM)Project D Wrote: I would go with C, it should make things a lot easier. I'm thinking that, I looked them up to check what position the inlet and outlet are in and I think it's close enough to be the least headache! A reputable brand to boot too (02-07-2018 12:18 PM)bozu Wrote: Option D perhaps, have a custom alu one built. I'm looking into that too as it would be the same lad that would be doing the alloy welding that would make one from scratch (Lee Smart Racing) but I've already considered that it would be much more expensive than anything off the shelf and probably no better than a Koyo. Keeping it in mind though as I'm going to him for a small bit of work anyway. |
PWR light issue and no brake fluid after winter storage | magpie | 10 | 1,575 |
Radiator & grill support panel (Levin) | FanIsHere | 5 | 1,531 |
11-14-2022 10:07 PM Last Post: Ivan141 |
Fuel pump issue | DJexor | 11 | 3,861 |
Alu thick core radiator fitment | Gtsi-R | 5 | 2,153 |
01-26-2022 01:28 PM Last Post: Gtsi-R |
Clutch Issue | Deaty | 8 | 3,598 |
04-09-2021 10:26 PM Last Post: Nakilad |
