will the 0.5 mm HEADGASKET clear?
01-23-2008, 01:27 PM
Hi,
do the valves interfere with pistons when the 0.5 mm headgasket is used? (in case of belt snaping)? -stock bluetop 4ag |
01-23-2008, 03:01 PM
They dont interfere when working, if the belt breaks, i dont know...
![]() Cump´s Filipe Oliveira |
01-23-2008, 04:58 PM
i mean when the piston is in top dead position and the valves at full lift. will it clear? a non interferance engine is a good insurace. just in case..
01-23-2008, 05:48 PM
Even with the stock gasket they will interfere in such case.Just to make you feel better, there is a tiny chance (i would say there's no chance but you never know
) for the valves to remain opened if the belt fails...Keep in mind that there are valve springs and camshaft inertia that play role in the above equation!
01-23-2008, 06:59 PM
with the standard engine, even if the belt brakes valves don't touch pistons, it's a non interference engine. with a small head gasket i don't know.
It's easy to try though !! install the head gasket , put the piston one in TDC and rotate both camshaft's independently, if they do 1 full turn both without touching anything u are still ok ( i would say that with the 0.8 gasket it's still ok , but with the 0.5 it might start to be an interference engine ( like 90% of the other engines on our roads)) |
01-23-2008, 07:33 PM
yeah i want to know before i actually buy such a headgasket.
01-23-2008, 09:30 PM
it wouldnt be a matter to me.
Just go for it. Put a new timing belt, it will last forever! ![]() Cump´s Filipe Oliveira |
01-23-2008, 09:59 PM
Lipinhu Wrote:it wouldnt be a matter to me. 84' AE86 Levin 96' 500HP WRX, powered by landikar
01-24-2008, 01:41 PM
Apolan Wrote:i mean when the piston is in top dead position and the valves at full lift. will it clear? a non interferance engine is a good insurace. just in case.. Found this on web (by billzilla) Quote:"You dummy-assemble the engine, (just one cylinder will do) with plasticine on the piston tops and lightly cover the top of the plasticine with oil so the valves don't stick. http://www.toymods.net/forums/showthread...694&page=2 |
01-24-2008, 02:18 PM
I have wiseco pistons, decked the head 0,60mm, decked the block 0,1mm, have a 0,8mm head gasket and TODA 288/7.9mm camshafts. There's interference on the intake side only.
I would say, almost sure of it, that if you install a 0,5mm head gasket with the head at stock trim, you will still have a non interference 4A-GE. Best regards |
| Clear Lenses | SniperGT | 85 | 100,315 |
12-16-2012 09:28 PM Last Post: Aram |
| Silvertop Headgasket? | byd1380 | 3 | 5,078 |
01-05-2009 06:02 PM Last Post: byd1380 |
| head skiming/size headgasket/hks f-con! | nick | 9 | 10,453 |
04-10-2008 06:17 PM Last Post: oldeskewltoy |
| about 5mm TRD headgasket | filh | 24 | 23,524 |
04-13-2007 08:25 PM Last Post: jamiemirror |
| 5mm headgasket | filh | 14 | 14,438 |
01-28-2007 08:29 AM Last Post: Plex |
![AEU86 AE86 - will the 0.5 mm HEADGASKET clear? [Image: AEU86 AE86 - will the 0.5 mm HEADGASKET clear?]](http://lipinhu.no.sapo.pt/sbanner.jpg)
