warm idle 1500 rpms wont go down.
04-01-2008, 08:34 AM
oil pressure
hai there.... i have same problem like you to.my oil pressure also at the peak when i turn on the key, then drop to the normal whan a few second.. yesterday i open and service my trottle body and AAC what i do to make sure the acc operate as normal first i put it into the my freeze and the result the coil totaly close then i boil it the result spring is open so that thing was normal... i also flush my coolant system.
... but my idle still at 2000 rpm at the cold enjin morning start... after i drive for 15 mile the idle drop to 1450 rpm... so what do you think..? |
Messages In This Thread |
warm idle 1500 rpms wont go down. - SilentScope111 - 03-11-2008, 02:55 PM
[] - SilentScope111 - 03-11-2008, 08:36 PM
First, eliminate the obvious.... - jondee86 - 03-12-2008, 08:44 AM
Re: First, eliminate the obvious.... - rikard - 03-31-2008, 07:02 PM
The Dyke theory.... - jondee86 - 04-01-2008, 06:25 AM
oil pressure - Ke_70+mr2 - 04-01-2008 08:34 AM
What's a cold morning in Malaysia ??? 25 deg ?? - jondee86 - 04-01-2008, 09:49 AM
Warm start problem | DJexor | 5 | 3,640 |
No idle below 2000 rpm rich running | Steller Engineering | 3 | 2,523 |
Engine starts/revs but no idle | GenkiMotors | 17 | 10,506 |
11-20-2021 04:12 AM Last Post: GenkiMotors |
exhaust odor/idle MOT issue | Ryo | 7 | 9,280 |
20v silvertop idle issue | AlexFourTwenty | 3 | 6,216 |
12-24-2017 03:27 AM Last Post: AlexFourTwenty |
