turbo 4age with 4agze pistons HELP
10-26-2010, 08:28 PM
Halo.I have ewrithing i nide to make my ae86 turbo but i have one problem:The rods from 4agze are 2 mm larges (42mm with bearings) and die from 4age 40 mm with bearings.
Wath kan i doo?I kan buy some big bearings? Or i must buy anader rods but wath from?
I Kann not puting the 4age rods because thei are too small on piston and are not strong enough.
Please anser explicit cose mi englisch its not so good.
Thenks!!!
10-26-2010, 09:24 PM
You will need the later, bigger crank from AE92 and newer models. Some AE92 with T-Vis will have the bigger crank and all of the small port AE92s have the bigger crank.
10-26-2010, 09:41 PM
http://cgi.ebay.com/ebaymotors/Toyota-Co...ccessories
With this kan i make samthing?
10-26-2010, 09:47 PM
Wath its this crank?
Sory.
10-26-2010, 10:04 PM
Those rods are for the bigger crank also as the 45mm big end bore when fitted with bearings will suit the 42mm crank journal. Did your country get the AE92 Corolla?
10-26-2010, 10:18 PM
I have bui som time agow this ae86 (i have 3 ae86) and i want too make this onlie for drifting.
I have 3 motors too ,kan bie oder one difrent? B.E Bore 45?
10-27-2010, 12:29 AM
Do you have access to a machinist?
The inside of the small end of the connecting rod can be enlarged from 18mm to 20mm.
As long as rpm levels stay under 7500 there should be no problem. rpm levels exceeding 7500 may be a problem
photos of 4AG stock connecting rods
[Image: AEU86 AE86 - turbo 4age with 4agze pistons HELP]
Dan -
10-27-2010, 10:04 PM
Smallport means 40 mm crank journal and bigport means 42mm crank journal?
Cose mi connecting rod have inside of the small end 18 mm and 40 mm crank journal.
10-28-2010, 06:28 PM
filip.alin Wrote:Smallport means 40 mm crank journal and bigport means 42mm crank journal?
actually it is the reverse. smallport is newer, uses larger rod journal crankshaft. The largeport is older, and it uses 40mm rod journals
Dan -
10-28-2010, 08:57 PM
OK .I have anderstend.Good that people like iou are.
Thenks.Wery wery much.
  82mm Stock compression Pistons apardal 4 3,966 11-24-2021 04:26 PM
Last Post: apardal
  whats the crack with 16v turbo? kazi 5 7,524 08-02-2017 12:15 AM
Last Post: kazi
  Small Port 10.3 Pistons Alex170984 1 5,036 10-25-2016 09:18 PM
  Bluetop on turbo leon205gti 7 9,328 09-20-2016 09:17 PM
Last Post: leon205gti
  can i just slam a oem turbo on it ? MC_JP 3 7,032 12-17-2014 11:04 PM
