techno toy tuning rear strut tower braces....installation ?.
09-11-2010, 07:47 AM
I just got the Techno toy tuning tri bar strut tower brace system for my 1985 GTS coupe. The rear brace has a two bolt bracket, but my coilovers only have a single bolt..... am I to retro fit this bracket or find one that fits the car?
09-11-2010, 08:05 AM
![]() this one? |
09-11-2010, 08:13 AM
that looks like the one, so is it a reto fit or bolt right up cause i have just a single bolt at the top of my coilover
09-11-2010, 10:21 AM
Just ask Gabriel...
09-11-2010, 03:40 PM
as far as I remember the rear braces aren't a directr fit so need drilling of the turrets to be fitted...
AE86 ex-daily |
09-11-2010, 08:30 PM
thats stupdi, why dont they make something that fits
09-11-2010, 09:49 PM
Bracing through that thin sheet metal is silly. I hope they include some serious plates to weld in.
09-11-2010, 10:04 PM
1. AE86 does not have rear struts/
2. Do not use the shock/damper stud for ANYTHING except mounting shock to the chassis. 3. If you want to brace & stiffen the body, then it has to be bolted directly to the body, not on a rubber shock mount, with multiple bolts & washers & preferably a backing plate. |
09-12-2010, 12:51 AM
Ok that was the "what". The "why" post that'll follow should be amusing.
09-14-2010, 01:39 AM
So this is the info that i recieved from techno toy tuning for anyone that may need the info
"On the hatch, there is a threaded socket under a small bit of tape in the rear tub for the tribar bracket." "On the coupe, you'll have to drill a hole as there is not one in the chassis." This is a link to a picture of the install. I had the same idea but just wanted to be sure. http://i96.photobucket.com/albums/l192/edpsx/hachi6.jpg |
| TUV - Strut brace | pack | 3 | 7,061 |
09-08-2018 08:17 PM Last Post: d3nso |
| Ecu ROM tuning | Alex170984 | 4 | 7,181 |
10-13-2013 08:03 AM Last Post: Apsogos |
| Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 7,568 |
| Need help (4ac engine tuning) | fullybuiltmiata | 3 | 7,834 |
08-20-2012 09:25 PM Last Post: banpei |
| Need urgent help strut mounts. | ditn | 5 | 9,241 |
01-21-2012 03:37 PM Last Post: ditn |
![AEU86 AE86 - techno toy tuning rear stru...llation ?. [Image: AEU86 AE86 - techno toy tuning rear stru...llation ?.]](http://www.technotoytuning.com/media/products/rtb_01.jpg)
