t50 gearbox shifting rough
02-20-2007, 08:40 PM
Hey guys,
Is it me that i've been spoiled with a smooth and direct shifting W50 tranny from my 21r powerd celica? I find my T50 tranny in my aa63 celica very hard to handle. Not smooth at all, I cant go trough the gears quick without cracking sounds from the gearwheels. Is it a fucked gearbox or are T50 boxes just shitty trannies? A sidequestion: Since i still have my W50 box in the wreck at home, how hard would it be to modify the W50 to suit a 4age? I reject your reality and substitute my own! No more Panda.. Tricolor bastard! If it 'aint broke, fix it 'til it is |
02-20-2007, 08:45 PM
I have no problems with my T50 but if you read around, when they get warn they seem to suck
W50 upgrade sounds like a nice idea Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
02-20-2007, 08:54 PM
exactly. My W50 box is a very nice box to handle. And it seems that those boxes are stronger then the T50's.
02-20-2007, 10:32 PM
You'll need a 4age to W bellhousing, they are specially made somewhere in the phillipines I believe.
Then you need to shorten the driveshaft too, unless you can use the one from your old celica. FABRICA MI DIEM, PVNC! |
02-20-2007, 11:24 PM
Dennis, you're just a pussy
I haven't got any problems with your car
02-20-2007, 11:37 PM
auto tranny fluid or redline shock proof...
02-21-2007, 12:36 AM
or just check current fluid levels first ????
02-21-2007, 01:21 AM
T50 sucks.... POS.... costly to rebuild.....
Either go with a W box or be a bit patient... I'm having an adapter manufactured that will mate the 4A bell housing to a Miata 6 speed. http://www.aeu86.org/viewtopic/t50-to-az...ues/t/4283 It won't be cheap... no where near as cheap as the W box conversion... but the gears will better match the 4AGE.... Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
| T50 gearbox | totta Crolla | 3 | 5,189 |
02-25-2022 02:35 PM Last Post: Project D |
| T50 TRD gearset | DidiDex | 7 | 13,630 |
09-12-2019 07:36 PM Last Post: DidiDex |
| Shifting from 4th to 3rd | pack | 7 | 10,127 |
04-27-2017 07:26 PM Last Post: totta Crolla |
| 4A-GE bellhousing on a 20 spline T50 | The Doctor | 2 | 9,322 |
09-30-2016 03:38 PM Last Post: The Doctor |
| T50 gearbox - TRD 2nd and 3rd gear | hachirokkos | 3 | 9,143 |
11-27-2015 10:06 AM Last Post: Project D |
