t50
12-08-2008, 11:08 PM
t50
do the t50 from 4ac the same t50 from aGE?
Rising Sun T |
12-08-2008, 11:46 PM
t50
The 4AC has a different bellhousing, but apart from that the t50 should be the same:
http://www.aeu86.org/index/engine-ae86-s...post=72098 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
12-09-2008, 03:53 AM
t50
The box is the same. The difference in the bellhousing is that the clutch slave cylinder is on the left-hand side for the 4ac and the righ-hand side for the 4age. You don't need to change the bellhousing, but you may have to shift the clutch slave around a bit so that it doesn't hit the exhaust.
Also, with that link, you don't need to replace the fuel lines if you don't have them. You can use the 4ac ones, just be creative, put the biggest line for fuel feed, and the smallest for venting. However, if you've got a complete 4age factory powered ae86 then do as the guy did and transfer everything. It'll be a much neater swap. Chris |
12-12-2008, 12:17 AM
t50
THANK U
ae family )) Rising Sun T |
12-12-2008, 12:29 AM
t50
Don't forget to change the speedo gear. SR5 speedo gear is different than the GTS.
-Brandon |
12-12-2008, 12:28 PM
t50
Forgot about that! It is different because it has a 4.1 final gear instead of the 4.3
| T50 gearbox | totta Crolla | 3 | 5,430 |
02-25-2022 02:35 PM Last Post: Project D |
| T50 TRD gearset | DidiDex | 7 | 14,039 |
09-12-2019 07:36 PM Last Post: DidiDex |
| 4A-GE bellhousing on a 20 spline T50 | The Doctor | 2 | 9,547 |
09-30-2016 03:38 PM Last Post: The Doctor |
| T50 gearbox - TRD 2nd and 3rd gear | hachirokkos | 3 | 9,414 |
| T50 Gearbox, Fragile ! | hachirokkos | 10 | 17,937 |
11-12-2015 12:06 PM Last Post: S.K. |
![AEU86 AE86 - t50 [Image: AEU86 AE86 - t50]](https://www.aeu86.org/sticker-banner-468.gif)
