starting help !!!!!!!!!!!!
04-11-2008, 06:17 PM
Hey all im new to the site, at the moment im having problem starting her up. The problem started last week when i start the car, it started alrite but once started the revs keeps dropping down until it stalls. So i tried keeping the revs up by pumping it but the more i pump the gas the less the engine revs and its so unstable. So i stopped and switched off the engine, i started again and the same thing happens but this time when i try and move forward it stalls it feels like theres no power at all. So i stopped again but now i cant even fire her up. I changed the ignitor/coil but that didnt help. Also changed the rotor arm and dizzy cap but that doesnt work either theres no spark coming out of the HT leads. The other reason i can think off is this HKS twin power ignition module it has. It Whines when theres elec to it and the indicator light doesnt come on
[Image: AEU86 AE86 - starting help !!!!!!!!!!!!]
maybe i have to replace it if anyone has one for sale Or is there another way
thx all
04-11-2008, 10:08 PM
Could be a bad power supply (high resistance) to the HKS unit.
May also be the fuel pump.
04-11-2008, 11:14 PM
the thing is it suddenly happened. hmmm...... hey u in oxford ? cos so am i ! im in wheatley
the problem is like the one from odeaten "ignition problem" but i didnt take the distributor off just changed the rotor arm and cap
04-12-2008, 10:00 AM
I had a similar problem, car would start, run for a few minutes and gradually lose power, I was convinced it was fuel pressure, but it turned out to be bad power to the ecu, check all you voltages.
Ivan
1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1
  lntermittent starting totta Crolla 6 7,178 08-31-2021 06:21 PM
Last Post: totta Crolla
  Starting problems 4-AGE kouki Hanzo 3 5,335 08-31-2021 06:20 PM
  JDM trueno not starting. need help! kazi 8 13,213 03-12-2017 05:05 PM
Last Post: kazi
  20v Starting Issues mad.matt 10 17,446 09-24-2014 12:44 PM
Last Post: pack
  starting/electrical issues Jezza_hr 14 25,797 12-21-2013 05:45 PM
Last Post: Apsogos
