sr5 idle help
06-16-2008, 12:37 AM
sr5 idle help
ok so i have a few Q for any of you that knows about carbs and the sr5. im new to carbs but i understand how they work. ok so first off when i start it off it will idle good if i have the idle set at 1500rpm but if i lower it than it will not stay steady, it will stay with in about 300 rpms tho, and it will start to get ruff at around 1000 to 800 and will sometimes die at around 800. now my second Q is when its warming up if i give it gas than it wold idle, if i give it gas than let off the gas than it will just die. i know alot of stuff about EFI but carbs i only know the basics of the basics so i dont really know much about them other than miner adjustments and how most of them work so any help would be nice.
06-16-2008, 09:56 AM
sr5 idle help
You only set the idle screw when engine is warm, just like EFI. Otherwise it won't idle correctly. Wink
Then the carburetor has a choke (comparable to the coldstart injector) and it is probably an automated choke (like most modern carbed cars have) so you better check if it is still working correctly. I think this what your problem possibly is. Tongue
Here you can find more info about how a carburetor works:
http://auto.howstuffworks.com/question377.htm
[Image: AEU86 AE86 - sr5 idle help]
06-17-2008, 01:10 AM
sr5 idle help
Have you checked the condition of your fuel pump?
Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
1989 Honda Civic Si-R Current Project
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
06-21-2008, 10:42 AM
sr5 idle help
hey thanks for the help.. sorry it took so long for me to get back.. my computer was acting up... but well i took it to get smoged and my tac. said it was at 1,500 but the dyno somg thingy said i was at 670 RPM's lol so i think my tac is a bit off so i think i will try and get one that i can hook up to makesure i set it at the 800 i think it is suposed to be at. but thanks for the help. im also going to clean the carb up a bit and see how that helps it.
06-22-2008, 10:18 AM
sr5 idle help
I had such a problem with my tach in the past as well so that doesn't surprise me at all. Tongue
06-22-2008, 11:04 AM
sr5 idle help
Maybe its a good idea to get a clean air filter along the way as well if you haven't already done so.
06-24-2008, 08:22 AM
sr5 idle help
ya and my temp gage is really sticky and liks to jump around from all the way hot to all the way cold and back to norm sometimes. well when i got the car it didnt have a air filter so it has a nice new one Smile but ya it seems to be running better now... now just to stop all the leaks from under the hood ;p
  Blacktop 20V high idle Bravothreezero 3 1,012 08-28-2026 01:11 PM
Last Post: jdm86gtz
  No idle below 2000 rpm rich running Steller Engineering 3 4,401 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Engine starts/revs but no idle GenkiMotors 17 15,327 11-20-2021 04:12 AM
Last Post: GenkiMotors
  exhaust odor/idle MOT issue Ryo 7 11,697 07-15-2019 09:17 AM
Last Post: jondee86
  20v silvertop idle issue AlexFourTwenty 3 7,729 12-24-2017 03:27 AM
Last Post: AlexFourTwenty
