spring platforms
03-31-2010, 09:57 PM
spring platforms
Stock struts, I want to cut and (professionally) re-weld the platforms 20mm higher.
any issues with this ?
04-01-2010, 10:15 AM
spring platforms
Not if you do it carefully.. Robokill used to have rally struts modified in this way (that are now coilovers in Doc's KE20). I'd use some beefy bumpstops so you can get to the end of a stage if a platforms fails.
04-01-2010, 01:17 PM
spring platforms
Thankyou.
Great idea with the bumpstops !
  SOME 4AG valve spring specs oldeskewltoy 5 16,448 05-04-2015 01:17 PM
Last Post: Project D
  clutch pedal return spring Eifelaner 2 9,163 09-06-2013 10:21 AM
Last Post: Apsogos
  P-valve CLOSED --> Stiffer spring will do it :) Dino86 1 4,533 04-05-2012 04:17 PM
Last Post: Dino86
  lowering spring information HELP martyg 1 4,486 09-27-2011 01:56 PM
Last Post: martyg
  clutches and spring washers position in 2 Way TRD diff???? T_AE86 3 6,865 09-01-2011 10:50 AM
Last Post: T_AE86
