some hints from www.toyota-workshops.de
04-24-2006, 05:23 PM
http://www.toyota-workshops.de/include.p...themeid=16
Found some tips for AE86. Can anyone translate it please ? My german is not so good. I think this are quite interesting tips :wink: . 85' AE86 GT coupe lifetime project since 2005 |
04-25-2006, 03:41 AM
Sure:
1. If the tranny starts to go and shifting becomes more difficult, exchange gearbox oil with ATF (auto-tranny fluid). 2. Exchange bushings with poly or TRD bushings throughout the car. 3. Checking the TVIS activation switch..(vacuum switch): start car to build up vacuum and switch off. Look at switch with help of a mirror. Have a helper put the ignitionswitch to ON (do not start). If al is well, the little lever on the switch should move and you should also hear a slight sound. Otherwise check connections for corrosion. A wheel to steer the front of the car A pedal to steer the rear |
04-25-2006, 05:44 PM
So that means if it gets a little hard to shift gears i should try to use oil for automatic tranny in T50 gearbox ? Well i dont know what means that it gets harder to shift but i have sometimes problems to shift 3 gear and 5 gear is a little louder than the others. So i can try to use 75w90 automatic tranny oil ? The question is if there will be no trouble with it and how long to use it ?
| S13 rear subframe.. hints and tips? | 4000GT | 2 | 6,573 |
07-15-2012 08:11 AM Last Post: 4000GT |
| Summer tires for AE86 - give some hints :) | Ryo | 10 | 15,135 |
04-22-2010 07:02 PM Last Post: Ryo |
