small port engine
07-01-2010, 12:34 AM
small port engine
small port engine with reversed intake.
Blue top sensors
Blue top ecu or Cusco MFE
Blue top injectors or red top green injectors
Bluetop harness
Potential problems with this setup please. Especially sensor placement on the smallport inlet.
Thanks
07-01-2010, 11:58 AM
small port engine
You will need to make a hole for the blue top IAT, and you will need a
smallport fuel rail. Everything else is pretty much the same between the
two engines. You will be swapping over the sensor block at the back of
the head, and using the RWD water pump and water lines. Use the RWD
alternator and brackets. Use the RWD crank pulley. That way, those three
pulleys will all line up. Small port uses a PWM idle-up valve, but you
should be OK with the blue top on/off idle-up valve.
Small port fueling will be a bit a bit different from the blue top, so you
will need a piggyback, adjustable FPR and/or the small port injectors to
get a bit of a tune going Smile
Cheers... jondee86
07-01-2010, 09:08 PM
small port engine
totta Crolla Wrote:small port engine with reversed intake.
Blue top sensors
Bluetop harness
Thanks
oh boy!!
cheers
Hurray! Thumbs up!
[Image: AEU86 AE86 - small port engine]
07-03-2010, 10:05 PM
small port engine
Excellent info as always. Thanks.
Sorry for the late reply, I have spent the last few days instructing disabled drivers for the Motability scheme here in the U.K
Totally rewarding few days it was too, I'm sure I learnt a lot more than they did. The courage and determination shown by all the participants was extraordinary Thumbs up!
  4AGE Big port head failure Blaze0010 3 477 01-23-2026 03:35 PM
Last Post: totta Crolla
  Early tvis red top from e9 gti small or bigport? Ryo 3 9,100 04-20-2018 09:14 AM
  Small Port Swap Alex170984 1 5,221 11-21-2016 01:46 PM
Last Post: Alex170984
  Small Port 10.3 Pistons Alex170984 1 5,401 10-25-2016 09:18 PM
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 10,069 10-30-2013 11:18 PM
