small port engine
07-01-2010, 12:34 AM
small port engine
small port engine with reversed intake.
Blue top sensors Blue top ecu or Cusco MFE Blue top injectors or red top green injectors Bluetop harness Potential problems with this setup please. Especially sensor placement on the smallport inlet. Thanks An analogue brain in a digital World |
07-01-2010, 11:58 AM
small port engine
You will need to make a hole for the blue top IAT, and you will need a
smallport fuel rail. Everything else is pretty much the same between the two engines. You will be swapping over the sensor block at the back of the head, and using the RWD water pump and water lines. Use the RWD alternator and brackets. Use the RWD crank pulley. That way, those three pulleys will all line up. Small port uses a PWM idle-up valve, but you should be OK with the blue top on/off idle-up valve. Small port fueling will be a bit a bit different from the blue top, so you will need a piggyback, adjustable FPR and/or the small port injectors to get a bit of a tune going ![]() Cheers... jondee86 |
07-01-2010, 09:08 PM
small port engine
totta Crolla Wrote:small port engine with reversed intake. oh boy!! cheers
07-03-2010, 10:05 PM
small port engine
Excellent info as always. Thanks.
Sorry for the late reply, I have spent the last few days instructing disabled drivers for the Motability scheme here in the U.K Totally rewarding few days it was too, I'm sure I learnt a lot more than they did. The courage and determination shown by all the participants was extraordinary An analogue brain in a digital World |
| 4AGE Big port head failure | Blaze0010 | 3 | 768 |
01-23-2026 03:35 PM Last Post: totta Crolla |
| Early tvis red top from e9 gti small or bigport? | Ryo | 3 | 9,291 |
| Small Port Swap | Alex170984 | 1 | 5,373 |
11-21-2016 01:46 PM Last Post: Alex170984 |
| Small Port 10.3 Pistons | Alex170984 | 1 | 5,561 |
10-25-2016 09:18 PM Last Post: oldeskewltoy |
| toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 10,342 |
![AEU86 AE86 - small port engine [Image: AEU86 AE86 - small port engine]](http://img704.imageshack.us/img704/7318/serchmarclogo.jpg)
