rough run/stall 4a-ge
03-26-2012, 04:22 AM
need a bit of help. 4age turbo has a rough run. Won't idle above 1100ish on warm-up. Sounds like its gunna stall at times and a little bit of oily water out the tailpipe. Any idea's? Thanks everyone!!!
EDIT: turbo manifold and exhaust also leak like a bastard if that makes a difference. Also noticed that after the car is warmed up it will stall at idle. I could be just driving around normal, push the clutch and the rpms will drop till it stalls out.... or just at a stop light on idle. Starts right back up tho.
Any help is awesome!
03-27-2012, 05:04 AM
bump, anyone? Please Thumbs up!
03-27-2012, 03:57 PM
fix all leaks first and if problem persist we can look further Wink
  Where to run the factory antenna cable andyling 2 5,352 09-30-2020 12:31 PM
Last Post: andyling
  Machining Pistons to run 20v head... And FCR's on a 20v? PazzaAE86 2 6,611 09-15-2013 01:08 AM
Last Post: jondee86
  Rough starts desertdriftAE86 5 6,685 03-01-2012 07:24 AM
Last Post: desertdriftAE86
  E/G stall after Right hand corner Dino86 10 14,582 03-27-2011 01:55 PM
Last Post: Dino86
  o2 sensor and rough idling alex-evo 8 8,781 11-26-2008 08:08 PM
Last Post: alex-evo
