removing engine mounts
02-07-2007, 03:11 PM
i have a set of TRD engine mounts to put in the hachi
but i cnt see how to remove the old ones
and i cant find it in the AE86 manual or the 4A-GE manual i downloaded from here
anyone have any ideas?
[Image: AEU86 AE86 - removing engine mounts]
DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS
02-07-2007, 04:22 PM
I dont think it´s too dificult to do that, if you have a crane or a jack (not the stock one, those with wheels and lever...).
One way, or another, you gonna need to get the car off the ground a bit to meke it easy to work underneath.
With the crane, hold the engine by the proper hooks, just to make it leveled/suspended, you dont need to lift it like you´re gonna take it out, and then change the mounts one by one. For me this is the easyest way, but its not easy to put the hands on a crane, but if you know someone, or can get one from somewhere else...
With the jack, never done it, but i think it will do it. Hold the engine as near as you can from the mount you want to change, and then lift it just a bit or ajust the height as you need to take out and put in the mounts.
In boths situations, the "one by one" substituition will work better, this way you dont have the risk to let the engine fall out of his place, so it wont damage, or worse, remember that you´ll work underneath it.
I never changed the mounts on a Corolla, but i did some swaps on other cars, changed cambelts (belive it or not, some cars you need to lean the engine to do this and of course, take out some mounts), but it is a general tip, will work.
Cump´s
Filipe Oliveira
  Pinout of some connectors needed for removing JB2 Koen 4 3,005 04-01-2026 07:27 PM
Last Post: Koen
  Lets talk engine mounts kazi 6 11,312 08-31-2017 12:46 PM
Last Post: parrot
  removing light switch ? (fixed) MC_JP 10 22,570 09-18-2014 05:16 PM
Last Post: MC_JP
  Removing front window trim zenki 7 16,701 09-07-2014 08:36 PM
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 11,257 10-30-2013 11:18 PM
