removing clocks
09-12-2006, 02:22 PM
removing clocks
so does anyone know how to remove the dash clocks the speedo and stuff,
does the dash have to come out
or do you just remove the black plastic cover then take the clock out
09-12-2006, 02:45 PM
removing clocks
I think it's just the steering wheel, dash cover and then the clock. Nothing more. Check the FSM, you can download it from this site, the link is in the technical FAQ Big Grin
09-12-2006, 03:21 PM
removing clocks
yeah just downloaded it earlier, yet to look through it Big Grin
suppose i will probably have to remove my cage as well, or atleast unbolt it anyway
09-12-2006, 03:48 PM
removing clocks
I didn't need to remove the steering wheel: I bent the black cover a bit and I was able to squeeze it between the dash and the steering wheel (in lowest position). However this may damage (e.g. break in half) your cover so it's better to do it by removing the steering wheel Wink
[Image: AEU86 AE86 - removing clocks]
09-12-2006, 05:26 PM
removing clocks
my steering wheel is only held on by 6 allan key bolts anyway since it is an aftermarket one
09-12-2006, 08:12 PM
removing clocks
I'd prefer the original...1 huge nut....much easier to work with than those allen bolts.
09-12-2006, 09:40 PM
removing clocks
trueno is the way Wrote:my steering wheel is only held on by 6 allan key bolts anyway since it is an aftermarket one
Auch! Sad
But is the steering wheels smaller than the oem steering wheel? Dumb question
09-12-2006, 09:42 PM
removing clocks
Auch! Sad
yes very much so
very small
09-13-2006, 09:16 AM
removing clocks
trueno is the way Wrote:yes very much so
very small
Then I think it should be possible to remove the black cover by putting the steeringwheel in the lowest position without much effort. Wink
09-13-2006, 11:12 AM
removing clocks
huh
my steering column isnt adjustable
  Pinout of some connectors needed for removing JB2 Koen 4 2,315 04-01-2026 07:27 PM
Last Post: Koen
  removing light switch ? (fixed) MC_JP 10 21,921 09-18-2014 05:16 PM
Last Post: MC_JP
  Removing front window trim zenki 7 16,247 09-07-2014 08:36 PM
  Removing interior plastics Jezza_hr 3 7,370 03-18-2013 11:41 PM
  Removing brake servo (booster) totta Crolla 1 5,159 09-17-2011 01:40 PM
Last Post: totta Crolla
