rear diff/propshaft clanking/banging at low speed
06-18-2010, 12:11 PM
I have some unsual noise in rear end, diff assembly.
Diff is TRD 2way, new with some 2000-3000 km. Whole rear end was rebuilt with new bearings and stuff.
Sometimes, when driving slow i here not so loud metal bang/clang noise.
It's connected with changing load on rear end, when i cut off power or push throttle, or press/release clutch. It doesn't happen allways, sometimes, like once in every 10 times i repeat this stuff.
Sounds like something hitting a metal, not loud.
My car doesn't have rear seats nor any dampening material, and the level of noise isn't loud. Level like normal knocking on wood ... Smile
Diff looks to be ok, it' works ok, there is standard whining at 80+ km/h but i believe it's normal. When we rebuild it, CWP was looking good.
It could be propshaft olso, maybe some connection has too much foreplay ?
Anyway, where to look, and should i be worried ?
Thanks
06-18-2010, 12:13 PM
it must be the usual noise of the 2way diffs. they are making noise at low speeds.
06-18-2010, 12:17 PM
I know they are making noise while cornering, but this happens when i'm driving straight, city-street drive, slow and with lot's of 1st/2nd gear, slow braking and accelerating.
06-18-2010, 08:19 PM
your car is too low for our street conditions so it hit the asphalt Tongue
06-20-2010, 02:03 AM
Errrrrr... no, thats not the problem Smile
I listened more carefull and came to conclusion that its related to press/release of clutch, gears are not important.
  How to: Repair low fuel warning sender Sanity Clause 3 41,991 05-19-2025 11:05 PM
Last Post: Sanity Clause
  Silver top low idle AlexFourTwenty 7 13,896 10-16-2017 10:22 PM
Last Post: AlexFourTwenty
  What is normal and low caster in Cusco camber plates?? T_AE86 9 19,123 01-07-2016 02:56 AM
Last Post: Deuce Cam
  Oil cooler -> low oil pressure Jan Pedersen 24 39,650 06-06-2013 07:36 PM
  Rear ae86 rear discs & pad part numbers? J-86 4 8,279 11-30-2012 06:32 PM
Last Post: J-86
User(s) browsing this thread:
