"How To" Build your own Fuel Pressure Meter
04-04-2005, 01:07 PM
I have an Apexi Rev/Speed Meter installed (like the G-Tech Pro Comp gauge toy). I set it to measure mid-accelaration from 80-120 km/h. I put in third gear and perform the test a couple of times. This is how i meause my mods - no gear change, no tire roll out. Smile
Now to the question: no, i did not notice any improvement. As a matter of fact i got way slower times. My quarter mile times worsen with 1-2 secs, depending on the fuel pressure settings. Now i use the regulator but it's set to the stock pressure.
Additional note: i changed my stock fuel pump since it was anable to keep the pressure more than 3.0 bar at high rpm. The test above was made with the new pump wich kept 4.0 bars without any problems through out the whole powerband.
regarding the injector question: yes, they are stock. I did performed another test - i used i wide band meter to see if the injectors are feeding enough fuel (a/f ration stuff...) and i found out that the a/f mixture was good enough - 12.5! So now i decided not to play with the f/p regulator untill more air is introduced to the engine Wink or valves are replaced!
...or both Tongue
1984 Toyota Corolla 4AGE 20v
2007 Subaru Impreza STi
Messages In This Thread
[] - jamiemirror - 03-25-2005, 08:44 PM
[] - cj - 03-26-2005, 02:14 PM
[] - filh - 04-01-2005, 08:38 PM
[] - cj - 04-04-2005 01:07 PM
[] - filh - 04-05-2005, 01:25 AM
[] - Brian - 06-10-2005, 07:19 AM
[] - Ivan141 - 06-10-2005, 09:09 AM
[] - LevinGT - 06-12-2005, 06:47 PM
  7AGE Build apardal 5 5,124 08-02-2024 12:11 PM
Last Post: apardal
  Can you convert your 86 back too the original state? gh0st 7 6,392 04-25-2022 04:25 PM
Last Post: gh0st
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 26,431 08-19-2018 12:08 PM
Last Post: AlexKTM
  How would/have you rebuild your 4age? joaotcgt 6 11,996 07-21-2015 10:40 AM
  Oil Pressure Query Alex170984 2 6,923 12-11-2014 01:25 AM
Last Post: Alex170984
