oldskull's Levin
06-04-2007, 05:20 PM
Post: #191
oldskull's Levin
Yes you got it, its not much but there is something strange with my car. it is more than 1mm and since i put koni yellow under my car and it is more lower than tokico blues or OEM shocks. anyway I think I need to check the align of my tyres too. Yeah I will answer your pm
06-12-2007, 09:29 PM
Post: #192
oldskull's Levin
Finally I installed T3 adjustment panhard rod yesterday. But with some stupid happened after everything installed then I lowered the jack and I went under the car to adjust them I found out that I cant adjust it at all because one of the nuts are fastened. So I am fed up I just stopped and continued today. Right know my rear wheels are centered Thumbs up! Hurray!
So only one more problem (left front suspension is lowered than the right side) need to be resolve. I will try to solve them after bushing, RCA and camber plates install.
06-12-2007, 09:55 PM
Post: #193
oldskull's Levin
Nice work - even though you had to try twice Wink
Your car is looking just great! I would go just a bit lower and the stance would be perfect Thumbs up!
[Image: AEU86 AE86 - oldskull's Levin]
06-12-2007, 10:35 PM
Post: #194
oldskull's Levin
Thanks Jan.
Yes I like to go a bit more lower but I need to take a good decision.
About few hundred meter from where I live there is a small village if I want to gone to Amsterdam, I should drive trough there even almost to anywhere I must drive trough that village first and I you drive to there my car will shaking like hell with my current suspensions. So if my suspensions too hard I will easily get crazy about it and get my back hurt. Tongue I am quite older now Sad
So I think it will take sometime to get my car lower only if some nice offer come around Tongue , so first saving some cent to get rust-protections and new paint Smile
06-12-2007, 10:53 PM
Post: #195
oldskull's Levin
Ohh I see Smile I know about getting older too: When I drove my 86 every day I didn't think it was THAT rough, but after driving something a bit more comfortable for two years...Well lets just say that I've gotten older Banging head I might have to buy some adj dampers for the front end - that would make it a lot smoother. There is quite a difference when I adjust the rear dampers Thumbs up!
06-12-2007, 10:56 PM
Post: #196
oldskull's Levin
yeah good idea about adjustment dampers for front end Smile I am thinking buying the hole set with easily adjustment without taking the struts apart Tongue (like koni)
06-12-2007, 11:03 PM
Post: #197
oldskull's Levin
It has to be done without taking anything apart! I'm running TRD and I'm sticking with them for sure! And they are only a bit more expensive than yellow Konis Thumbs up!
06-13-2007, 01:00 AM
Post: #198
oldskull's Levin
grandapas. Tongue
06-13-2007, 08:13 AM
Post: #199
oldskull's Levin
oldskull Wrote:About few hundred meter from where I live there is a small village if I want to gone to Amsterdam, I should drive trough there even almost to anywhere I must drive trough that village first and I you drive to there my car will shaking like hell with my current suspensions. So if my suspensions too hard I will easily get crazy about it and get my back hurt. Tongue I am quite older now Sad
I assume you mean the route right through the forest and next to the moor (heide). If you're talking about speedbumps: then you have to be careful not to drive to quick over them, if you're talking about the stone-roads you better keep the car going and push it hard. >Smile
Atleast, that's what I found out with the previous springs under my car. Tongue
06-13-2007, 09:11 AM
Post: #200
oldskull's Levin
Apolan Wrote:grandapas. Tongue
HEYHEYHEY! Angry :wink:
